Go to Post Corndog is the new water game. - Basel A [more]
Unread 24-01-2010, 14:14
Wendy Holladay's Avatar
Wendy Holladay Wendy Holladay is offline
FRC #1912 (Team Combustion)
Wendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond repute
Field Numbering
For this years game, how are the zones numbered? Is the zone nearest to the driver zone 1 or zone 3? Or is the numbering independent of what team you are on? I am wondering because on the driver station, you can set station Red 1-3, or Blue 1-3. The team color is obvious and you can easily assume position 2 is in the middle. However, which side is position 1 and which is position 3?
Unread 24-01-2010, 14:24
Re: Field Numbering
By tradition: Robot placement doesn't matter; just be in the right place to be in a starting zone. Driver stations are 1, 2, 3 L->R on each side.
I'm pretty sure that in competition, this will be set automatically. Don't worry about it too much.
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Re: Field Numbering
Blue Zone, Midfield, Red Zone (no numbers)
Unread 24-01-2010, 15:15
Re: Field Numbering
To amplify what Eric said, the position numbers refer to which spot in the alliance station your drivers are set up in. They have nothing to do with where on the field your robot begins. If your autonomous strategy changes based on which zone you're starting out in, you'll need to find your own way for the robot to know where it is.
Perhaps the apparent size of the vision target could be helpful here. Perhaps you can figure out a way to get the information from the Driver Station before the match begins. Perhaps a three-position switch on your robot is the best answer.
Unread 24-01-2010, 15:38
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Field Numbering
Also, don't count on the system telling you what color your robot is either. There is a variable that should be populated, but we had inconsistent results last year. We also thought the field told us which position we started in as well.
We managed to score a few times in portland during autonomous last year, and it was pure luck that the robot got the right color information those times.
As Alan said, the best way is to directly tell the robot either via a switch on the DS or a switch on the robot.
[FTC]: Full Field vs Low-cost Field 595294001 FIRST Tech Challenge 13 04-05-2011 19:10
Field Corner Dimensions Missing from Field Drawings? Don Wright General Forum 2 13-01-2009 19:57
Field??? hiimcristhian General Forum 2 07-02-2008 21:53
Greek numbering system Charger_07 Chit-Chat 2 07-03-2006 23:39
Team Numbering System? Nuttyman54 General Forum 37 03-01-2006 15:46
