Go to Post (Just remember to pack extra warm--when they say the state motto is Live, Freeze, or Die, they're not joking.) - Billfred [more]
Unread 24-01-2010, 16:28
chsrobotics3283's Avatar
chsrobotics3283 chsrobotics3283 is offline
FRC #3283 (Clarksburg Robotics)
chsrobotics3283 is an unknown quantity at this point
4 motors
What would you have to do if you want 4 motor controllers, with one joystick?
Unread 24-01-2010, 16:50
Re: 4 motors
In Begin.vi do a
right-click-> Replace -> Robot Drive Palette
on "Drive - Open 2 Motors" to change it to "Drive - Open 4 Motors".
Then specify the 4 PWMs to be used.
Unread 24-01-2010, 21:02
Re: 4 motors
Ok thanks a lot thats what I thought at first.
Unread 25-01-2010, 00:28
Integral Integral is offline
AKA: Ross
FRC #1130 (Robo Rebels)
Integral is an unknown quantity at this point
Re: 4 motors
The hardware option is to run 2 motor controllers via 1 PWM port and a PWM Y cable.
Unread 25-01-2010, 20:46
grosh grosh is offline
FRC #2147
grosh is an unknown quantity at this point
Re: 4 motors
I don't think this is permitted by rule <R49> "Each power-regulating device (speed controller or relay module) shall control one and only one electrical load (motor actuator or compressor)"
We are also trying to change the 2010 Game Robot Project to drive with four motors & we have changed to Tank Drive. We have replaced the"Drive - Open 2 Motors" to "Drive - Open 4 Motors", but the robot is only driving with the same two wheels it drove with using the "Drive- Open 2 motor".
Is there another step we need to complete because we have also changed to tank drive?
I've attached a copy of our Begin VI.
Can anyone advise?
Name:	4 motors.jpg
Unread 25-01-2010, 21:00
Re: 4 motors
The Y cable connects one PWM output from the Digital Sidecar to two speed controllers. Each speed controller goes to a single motor; each motor comes from a single speed controller. <R49> is satisfied.
Can anyone advise?
The vi you posted looks right. My first thought is that perhaps you're not deploying the code to run at startup, and the cRIO is still running what was last loaded successfully. You might try to run the Robot Main vi (using the white "run" arrow) and see if it works that way.
Unread 25-01-2010, 21:14
FRC #2147
Re: 4 motors
Thanks for the clarification! The wiring option will work. Thanks again
Unread 28-01-2010, 14:37
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Re: 4 motors
The Y-cable PWM adapters come in the KOP. I have used them in two past years.
We had two motors on each gear box. We absolutely did not want them to do anything other than exactly the same thing. Using the Y-cable keeps the program simpler, saves a PWM output and prevents a code mistake from possibly running the motors in different directions.
Whether you use the Y-cable depends on whether you need independent control of each motor, or whether they will be always working together.
They can save you some coding and spare a PWM output at the expense of some flexibility. It won't save you a motor controller, because as stated perviously, you still need one for each motor. You can do this with either Victors or Jaguars. (Although I wouldn't mix them.)
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Modifying motors for 2009 FRC motors Ramiro_T General Forum 2 22-03-2009 01:33
Motors, Motors, and More Motors 1033missions Motors 1 09-02-2006 18:46
Motors.. and more motors.. How many on your 2004 bot? OneAngryDaisy Motors 33 23-02-2004 00:46
Matching Drill Motors and Fischer-Price Motors archiver 2001 5 24-06-2002 00:51
F.P. Motors & gearbox for $12.50 Window Motors $19.50 archiver 2001 1 23-06-2002 23:05
