Go to Post It's like the people from Pimp my Pit came and had it professionally done. - [more]
Unread 24-01-2010, 17:10
FRC4ME FRC4ME is offline
FRC #0339
FRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant future
Java PWM getPosition() integer division bug?
After much troubleshooting trying to figure out why Servo.get() was returning 0.0 for any servo position other than 1.0, I noticed the following code in edu.wpi.first.wpilibj.PWM:
public double getPosition() {
    int value = getRaw();
    if (value < getMinNegativePwm()) {
        return 0.0;
    } else if (value > getMaxPositivePwm()) {
        return 1.0;
    } else {
        return (value - getMinNegativePwm()) / getFullRangeScaleFactor();
Notice the final return statement. value, getMinNegativePwm(), and getFullRangeScaleFactor() are all of type int. Would this not cause the integer division to truncate to 0 for any result less than 1? I checked the C++ version of the same function, and sure enough, the numerator and denominator of the fraction are cast to float before the division.
Go directly to queue. Do not pass pit.
**FIRST EMAIL**/Java and Orbit Balls *****JAVA DISCUSSION*** Pjohn1959 Programming 37 31-08-2009 15:55
Using Integer variables programmr Programming 4 14-02-2009 17:26
Displaying a 16 bit integer on PIC 16F877? Ian Curtis Programming 4 20-06-2008 15:42
integer division ImmortalAres Programming 5 11-07-2005 21:19
Integer Number powercat Programming 2 18-02-2003 11:26
