Go to Post There are times when we talk as friends and joke around about things like this, but then the most important times are when he says "I'm telling you this as a mentor," no matter what it is, those moments mean a lot. - Akash Rastogi [more]
Unread 24-01-2010, 18:15
Dark element's Avatar
Dark element Dark element is offline
Angelo Gargarello
AKA: Angelo Gargarello
None #0005 (robocards)
Dark element will become famous soon enough
Send a message via MSN to Dark element
Auto off air compressior code
Hello I was just wondering where to find the code that automatically. turns off the air compressor. Thank you
Melvindale Robocards team #5
Contact me at
theoldelement@gmail.com
Founder and Owner of The Old Element
Unread 24-01-2010, 18:19
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Auto off air compressior code
WPIlib in LabVIEW has a set of blocks to open, start, stop, and close the Compressor. When you open a compressor, you set the slot and port of the compressor AND the pressure switch. The set of blocks for the compressor will automatically handle the pressure switch for you. If you aren't using LabVIEW, the code associated for the compressor will automatically handle the pressure switch.
Kettering Motorsports
Unread 24-01-2010, 18:21
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Is there a C++ lib for this also?
Unread 24-01-2010, 18:23
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
It should automatically handle the switch I guess.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 24-01-2010, 18:31
Michael DiRamio Michael DiRamio is offline
FRC #1114 (Simbotics)
Michael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond repute
In C++ and Java, after you create a compressor object and call its start method it will automatically turn the compressor on and off as needed.
You need to make sure you have the pressure switch wired up to a digital input correctly and that you specify the correct spike relay and digital input for the pressure switch when you create the object.
Unread 24-01-2010, 18:38
Angelo Gargarello
Thank you for your post and I found it is the 2005 code
relay8_fwd = !rc_dig_in18; /* Power pump only if pressure switch is off. */
relay8_rev = 0;
Thank you for your support
Contact me at
Last edited by Dark element : 24-01-2010 at 19:03. Reason: found what I was looking for
Unread 24-01-2010, 19:04
In 2005 the code needed a single line of code:
The pressure switch connects to Digital Input 18
The Spike for the compressor is controlled by Relay 8
Unread 24-01-2010, 19:24
Angelo Gargarello
Ok now how can I change when the pump turns on and off
Contact me at
Unread 24-01-2010, 20:10
Whatever you want to do:
relay8_rev = 0; /* stays this way and doesn't change */
relay8_fwd = 1 /* Turns the compressor on */
relay8_fwd = 0 /* Turns the compressor off */
Unread 26-01-2010, 12:49
luc.bettaieb's Avatar
luc.bettaieb luc.bettaieb is offline
AKA: Luc Bettaieb
FRC #1329 (Roborebels)
luc.bettaieb is an unknown quantity at this point
This is all very useful stuff. Thanks!
Unread 26-01-2010, 13:50
Racer26 Racer26 is offline
word of warning: 2005 code WONT work on your cRIOs. it was written under a MUCH different system, with completely different interfacing to the relays (Spikes) and motor controllers (jaguar/victor)
Auto Code ERROR 401 Programming 1 19-02-2009 00:53
Off robot air compressor sanddrag Rules/Strategy 52 11-01-2007 15:11
Air compressor never shuts off Carl Owenby Pneumatics 4 08-02-2003 23:34
Auto Air Pump Code zorro Programming 25 05-01-2003 16:50
[white paper] Auto-Balance Gyro Code Brandon Martus Technical Discussion 3 21-06-2001 10:36
