Go to Post I suggest that you don't discuss...sensitive issues about your team on this public forum. - Andy Baker [more]
Unread 24-01-2010, 19:33
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Camera Solution
Originally Posted by ideasrule View Post
Also, seeing a compass on your driver station doesn't mean that the update works. We uninstalled and reinstalled the update and our dashboard looked exactly as it should, but the camera feed still didn't work. We had to go to Program Files and manually delete ALL of the driver station software and reinstall it before the camera feed worked.
Correct, things should be installed as per this post: http://www.chiefdelphi.com/forums/sh...9&postcount=44 For us, the compass did not display until we had done that.
Unread 24-01-2010, 19:41
ideasrule's Avatar
ideasrule ideasrule is offline
FRC #0610 (Coyotes)
ideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the rough
Re: Camera Solution
I meant to say that following those instructions did not work. We did exactly what the instructions said, but still had no feed. We had to browse to C:\Program Files, find the Driver Station folder, manually delete it (as in, delete it using the "Delete" button on the keyboard), and reinstall it again before the feed worked.
Unread 29-01-2010, 20:13
Teh1337Bix's Avatar
Teh1337Bix Teh1337Bix is offline
None #3132
Teh1337Bix is an unknown quantity at this point
Re: Camera Solution
That's great but it doesn't solve my problem. I need to declare a camera variable with a class scope and then assign to it in the classes constructor, yet every time I put it in the class it gives me error.
Yes I'm Aussie, and yes I ride a kangaroo to school.
Yeah bruduz!!!
Unread 29-01-2010, 21:40
TPNigl TPNigl is offline
FRC #0069 (Team HYPER)
TPNigl is an unknown quantity at this point
Re: Camera Solution
We just got our camera working today, which was very exciting. The simple solution after all the updates was just putting in those few lines of code from the OP. Should've seen that coming, but ah well. Here's to hopefully solving many other confused teams' problems.
2011 Pit Crew:
2011 CT Xerox Creativity Award
HYPER Alumni
Unread 30-01-2010, 13:11
Sauce Sauce is offline
FRC #1245 (Shazbots)
Sauce is an unknown quantity at this point
Re: Camera Solution
Thanks a lot man, this worked!
Unread 31-01-2010, 23:53
K3V1N.Team70's Avatar
K3V1N.Team70 K3V1N.Team70 is offline
Team 70 Programmer
AKA: Kevin Stephens
FRC #0070 (70 More Martians)
K3V1N.Team70 is an unknown quantity at this point
Send a message via AIM to K3V1N.Team70
Re: Camera Solution
OK, We here in Goodrich, MI have completed all of these steps and this does not work for us. we are using c++, we have been using the 2010ImageDemo and it seems to have all the code posted above, we have all the updates and the camera works through the Ethernet port on the DS, we have had no luck here and would appreciate some help.
Thanks in advance, Team 494 & 70
Unread 01-02-2010, 10:09
bcieslak
Posts: n/a
Re: Camera Solution
Are you using the orange crossover cable between the camera and the cRIO??
We're having the same problems you are and we did not have any success yet either.
BC
Unread 01-02-2010, 19:07
Al3+'s Avatar
Al3+ Al3+ is offline
ARTist
AKA: Anthony
FRC #0840 (Aragon Robotics Team)
Al3+ is a jewel in the roughAl3+ is a jewel in the roughAl3+ is a jewel in the rough
Re: Camera Solution
Thanks for this! We just got our camera up and running.
To the above, we had that problem too earlier. When we tried to use a regular ethernet cable, the lights on the port on the cRIO weren't blinking. With the proper crossover cable (it was pink in this year's kit), the lights were blinking and we were able to get images on the screen. Are they blinking for you guys?
As for the code, where is the proper place to set up the camera instance? The way it is right now (in OperatorControl) it seems like the bot would stand still for 10 seconds at the beginning of the round.
cout << "Hello, robotics. Goodbye, world." << endl;
"The two-axis accelerometer provided in the kit of parts (shown in the picture below) is a two-axis accelerometer." - WPILib User's Guide
Unread 01-02-2010, 19:54
Re: Camera Solution
You put the declaration of the camera object in the first set of brackets after the imports, and the rest in robotInit
2011 Pit Crew:
HYPER Alumni
Solution to camera problem techkid7 Programming 1 12-01-2009 08:42
Adams Coprocessor Solution ScottWalls Programming 17 30-01-2007 17:17
Dean's Homework Solution Jessica! General Forum 1 08-05-2006 10:27
the solution focus fanatic Chit-Chat 8 18-01-2006 15:36
