Go to Post Please share your opinion and post whatever you want, I wouldn’t mind. Because I may be wrong. - Arefin Bari [more]
Unread 24-01-2010, 19:05
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Roller/Gatherer Test
This was our test for a sort of gatherer, seems to work nicely
http://www.youtube.com/user/Frcteam1592
This is on our test bot, not the actual robot that we will use
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 24-01-2010, 19:13
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: Roller/Gatherer Test
cool! cant wait to see you guys at UCF
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 24-01-2010, 19:29
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Would you mind sharing the RPM (or motor and gearing) and OD of the roller?
Unread 24-01-2010, 19:36
run the trap!!!
Team Role: Human Player
And the material.
-Philip J. Fry
Unread 24-01-2010, 19:42
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
This is cool, though of doing something like this with a little twist so the ball always stays in the middle of the roller, i'd like to see the roller tested on a mecanum drive driving sideways to see if the ball still stays in place.
2012-2016 Wave Robotics Team 2826
Unread 24-01-2010, 19:43
BrianT103's Avatar
BrianT103 BrianT103 is offline
AKA: Brian Taylor a.ka. BT
FRC #0103 (Cybersonics)
BrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud of
Send a message via AIM to BrianT103
Looks like they are using a pool noodle. Looks good.
Unread 24-01-2010, 19:44
dodar's Avatar
ya, we had that idea too of doing like an archimedes screw towards the center from both sides so it stays centered but it will be hard cause then how it touches the ball will change too
sportzkrazzy's Avatar
sportzkrazzy sportzkrazzy is offline
AKA: Zac
FRC #1592 (Bionic tigers and 801 Horse power)
sportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant future
Send a message via AIM to sportzkrazzy
I'll give u a hint the roller is something that will be on ever1s bot.... as for the other stuff test it
Unread 24-01-2010, 19:45
dodar's Avatar
Dude, someone already guessed it lol
Unread 24-01-2010, 19:47
AKA: Zac
Brian cheats
Unread 24-01-2010, 19:52
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
We have tested the roller concept and plan on implementing it. I am writing up our parts order for our dribbler system right now actually.
I was just hoping to get additional test data to supplement ours
Unread 24-01-2010, 20:05
Phoenix Spud's Avatar
Phoenix Spud Phoenix Spud is offline
Everyone. Everywhere.
FRC #3132 (Thunder Down Under)
Phoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond repute
I hate to sound like a safety-maniac, but I was safety captain on my old team for the past 2 years and sometimes I just can't resist! (Sorry if this sounds mean, I just would hate for someone to get hurt )
The person in the background was holding wires into the battery, this is a huge safety violation. That battery outputs enough current to kill you, and it should be handled safely!!!
Sarah Heimlich
Outreach Mentor | Business Mentor
FIRST® TEAM 3132
Unread 24-01-2010, 20:08
AKA: Zac
Yeah its wired correctly now. =)
And no worries we only lost one person (sarcasm mark)
Unread 24-01-2010, 20:40
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
great post!
Similar to what we will do, except heater pipe insulation.
Unread 24-01-2010, 20:50
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
Originally Posted by waialua359 View Post
great post!
they have heater pipes in Hawaii?
nice roller how well does it work when the robot spins 360?
roller chains Peter Randall Inventor 1 30-03-2009 17:21
Flanged Roller Bearings roboticWanderor Technical Discussion 10 25-08-2008 09:23
Roller chains generator Daniel_H Inventor 5 14-01-2008 19:50
Roller Prototype sdexp Robot Showcase 0 04-02-2006 22:41
Roller Chain Adrian Wong Inventor 3 23-02-2002 17:21
