Go to Post 3 weeks vacation here...every single day devoted to volunteering for FIRST. Am I crazy? Yes...I am most definately crazy...but crazy has never been this much fun. - Andy Grady [more]
Unread 24-01-2010, 18:40
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
Flow control valve recommendation
Hi, were attempting to have three kicking distances by varying the flow rate to a cylinder. It was suggested that we use multiple adjustable flow control valves or needle valves with multiple solenoid valves for each flow rate.
Has anyone done this before? Were trying to stay away from mechnisms for the kicker. If you have experience with this could you recommend who to buy the valves from? Were new to the and want to do it right the first time.
Much appreciate for your time!
Unread 24-01-2010, 19:43
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Re: Flow control valve recommendation
I think what you'll find is you can't get _enough_ flow to make a cylinder work effectively. Do you have any cylinders to make a prototype? In our testing a simple kicker could roll the ball, but not lift it the minimum 12".
We've done some experimentation, and the result is that a narrow cylinder will extend quickly, but not impart much energy into the ball. The large cylinder, while it looks like it should do the job, is starved for air because of the narrow tubes, valves, regulator, and can't extend very fast.
The cylinders, particularly the larger ones, work like dampers, resisting moving faster with increasing force.
Some teams are working on "pre-charging" the cylinders, where the piston is partially extended, physically blocked and filled with the 60psi air, then released quickly.
That said, you can connect two solenoids feeding one piston that have different flow control connectors (inline ones are convenient), or use a second regulator on the other circuit. If the regulator is downstream from the valve you can get pressures lower than the 30psi needed to activate the solenoid.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 24-01-2010, 20:23
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Here is our piping diagram. We are using 3 solenoids to preserve the air pressure in our 60 psi surge volume during kicker retraction. It's just a quick sketch, so if something doesn't make sense, or there is a mistake let me know. Like I have to ask.
https://docs.google.com/leaf?id=0B1A...ut=list&num=50
Solenoid Control Valve Question ttldomination Pneumatics 14 24-02-2010 19:08
Sprinkler system valve as a pneumatics quick Release valve Tank2010 Technical Discussion 11 25-01-2010 18:54
Awesome College Class Recommendation Eugenia Gabrielov Chit-Chat 2 11-01-2005 22:40
confirmed... 6WD recommendation of Joe J.. archiver 2001 0 23-06-2002 23:20
Penumatic Flow Control Valve Jon Lawton Pneumatics 9 15-02-2002 11:22
