Go to Post One time I had to write a report on "What is Gracious Professionalism?" I wrote down "Andy Baker" and got an A . - Swan217 [more]
Unread 24-01-2010, 21:41
Technic-R-C Technic-R-C is offline
FRC #2358
Technic-R-C is an unknown quantity at this point
Labview Programming Help
Hey,
I have a question for you guys.
When I load labview and attempt to run the sample 2010 Breakaway FRC template code (with a bit of modifitactions - added compressor VI and Relay VI's in the teleop code) the code does NOT enter execute mode (stays in init mode). I tried to counter this my making the teleop case structure set to execute through a constant but that gave out errors...) When I build the project and deploy/run as startup and then switch to driver station mode the code does not work...
Quick Clarification: I can't seem to find the experimental framework.. did they remove it?
When I try to run regular sample VI's the code seems to be running (using lightbulb debug) but the cRIO does not respond to the commands... I am really frustrated and would appreciate your guys input.
I have formatted the cRIO but I think I might as well do it again. I don't have the camera connected while running the code so this might be causing the teleop mode "init" hangup
Thank you and best regards,
Technic-R-C
Labview servo programming Delvadar NI LabVIEW 9 01-02-2010 20:29
Programming Mecanums in Labview Hadi379 NI LabVIEW 6 21-01-2010 19:45
Labview programming help - Deploy mode not working ferc Programming 3 20-10-2009 18:32
Joystick Button Programming in Labview Help Needed domoarigato NI LabVIEW 11 28-01-2009 10:55
FRC LabVIEW programming dlesley National Instruments LabVIEW and Data Acquisition 2 15-12-2008 13:21
