Go to Post Designing for failure tends to encourage failure. Worrying about failure analysis during the competition can become a self fulfilling prophesy. Break your pots in the fall and learn how to keep them from breaking. - Mike Betts [more]
Unread 22-01-2010, 13:09
aatuck aatuck is offline
AKA: Aaron Tucker
aatuck is an unknown quantity at this point
Team 449 Kicker Prototype Videos
Hey everyone, this is one of our first video posts, so...
Some videos that we had fun shooting last weekend:
http://www.youtube.com/watch?v=ijG1rNn8vvQ
http://www.youtube.com/watch?v=4wEt9wG36CY
And we did test it before to make sure that this would work...
http://www.youtube.com/watch?v=nRfEDClxQG4
This version isn't triggered by any robot-controlled parts, so right now we're prototyping various pullback and release mechanisms.
Unread 22-01-2010, 18:24
SamMullen SamMullen is offline
Team Alumni
FRC #0360 (Revolution)
SamMullen is a jewel in the roughSamMullen is a jewel in the roughSamMullen is a jewel in the rough
Re: Team 449 Kicker Prototype Videos
The next time you post a video, would you mind showing a closer look at the mechanism? The results were amazing, but I would really like to see how you did this in the first place.
Unread 22-01-2010, 19:09
AKA: Aaron Tucker
Sure, basically right now we have the kicker assembled as two bars coming down perpendicular from a main axle (parallel with the front of the robot), and a bar between the two. There's a bar in the middle of the kicker, and another on the front of the robot (which functions as a hard stop), and latex goes between the two.
We're not totally sure how well this mechanism will translate into the robot though, because the mechanisms so that a motor will pull it back, or release it are still being worked on. We got it to pull back decently (once the motor arrives), but aren't entirely sure if our release will be strong enough.
Unread 24-01-2010, 22:32
aclapper21 aclapper21 is offline
FRC #3015
aclapper21 is an unknown quantity at this point
Our team has a kicker similar to yours... we are using the tension of the surgical tubes to actuate our kicker. We too had problems figuring out how to load and release our kicker without interfering with the tension of the surgical tubes. Our solution to the problem was to use pneumatics to load the kicker and then used a simple gate latch that we found at Lowes.
The gate latch that we used was this:
http://www.lowes.com/pd_51080-1277-S...87149&Ntt=gate latch&Ntk=i_products&pl=1&currentURL=/pl__0__s?newSearch=true$Ntt=gate latch
we replaced the part of the latch on the kicker with a u-bolt so that the latch could be centered. Our pneumatics are not connected to the actual kicker. The pneumatics are just used to load the kicker into the latch and then the pneumatics are retracted back so that once the kicker is release from the latch the pneumatics do not cause a resistance against the pulling from the surgical tubing.
here is a video showing how we load our kicker... sorry that it is sideways!
http://www.youtube.com/watch?v=85GhXHJaWW8
hope this helps!
#1860 kicker prototype sloteera General Forum 12 04-02-2010 14:27
Rookie team kicker prototype teamrocket Robot Showcase 1 22-01-2010 00:00
Rookie Team 3357 The COMETS Kicker Prototype GGCO Robot Showcase 21 19-01-2010 23:06
Team 39 - Kicker prototype video TotalChaos Robot Showcase 10 18-01-2010 16:38
Team 241's Turret Prototype ontop of the Harvester Prototype Dantvman27 Robot Showcase 39 08-02-2009 22:53
