Go to Post you can't eat a poof ball. its filled with magic smoke. it'd kill you quicker than a robot rampaging in autonomous mode, when you have the green light strapped to your face. - efoote868 [more]
Unread 24-01-2010, 22:52
Technic-R-C Technic-R-C is offline
FRC #2358
Technic-R-C is an unknown quantity at this point
Re: Labview Programming Help
Originally Posted by Mark McLeod View Post
Try running a new copy of the default code just to see if it works without any changes.
That baseline will tell us if it's an operator error or coding error.
Are the statuses on the Driver Station and the RSL on the Digital Sidecar okay?
P.S. The experimental framework was removed with LabVIEW Update 2.0
Ok I will try that out tomorrow. The statuses on the Driver Station were good (3 green LED indicators) and the digital sidecar seemed fine..
Thats what I thought when it came to the experimental framework.. oh well.
Thank you, I'll get back to you tomorrow
Technic-R-C
Labview servo programming Delvadar NI LabVIEW 9 01-02-2010 20:29
Programming Mecanums in Labview Hadi379 NI LabVIEW 6 21-01-2010 19:45
Labview programming help - Deploy mode not working ferc Programming 3 20-10-2009 18:32
Joystick Button Programming in Labview Help Needed domoarigato NI LabVIEW 11 28-01-2009 10:55
FRC LabVIEW programming dlesley National Instruments LabVIEW and Data Acquisition 2 15-12-2008 13:21
