Go to Post You'll want to start with P, add some D to help prevent overshoot, and then add some I to help it get to the correct height if it isn't there from the P and D. - AustinSchuh [more]
Unread 24-01-2010, 19:32
ideasrule's Avatar
ideasrule ideasrule is offline
FRC #0610 (Coyotes)
ideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the rough
2010 FRC Camera Live Feed Lag
We managed to get the live feed working, the only problem being that it isn't live. At first, with the camera set to low resolution and a moderate amount of compression, there was around 5 seconds of lag (and a similar frame rate). Then Patrick logged into the camera, did something, and the lag magically became 0.5 s with a 2Hz frame rate. The following conversation ensued:
Me: What did you do?
Patrick: I changed it to all the best settings. (640x480, 0 compression, etc)
Me: And then it worked.
Patrick: Right.
We tried everything to try and reduce the lag to something acceptable. Decreasing resolution and increasing compression both increased lag time, while changing the exposure/white balance settings did nothing. We did install the Labview update, the DS update, and all of that. We did create a FRC/FRC account. We did image the cRIO with v19.
Help!
Unread 24-01-2010, 19:43
DonRotolo's Avatar
Back to humble
FRC #0832
Re: 2010 FRC Camera Live Feed Lag
Reducing compression reduces load on the processor.
Smaller frame size means less data to fit through that (relatively) tiny pipeline
Fewer frames per second also means less data. 2 Hz is 2 frames per second, 1/2 second lag is the best you can get at that frame rate.
Unread 24-01-2010, 19:49
ideasrule's Avatar
FRC #0610 (Coyotes)
I thought so too, but decreasing frame size increased lag time.
I know that, but I want to both reduce lag and increase frame rate, not one or the other. (I didn't manually set the frame rate; I let the camera do that.)
Unread 24-01-2010, 22:24
This is more lag that I'd expect. Can you describe how you are running the code and the DS? Can you describe the development tools?
Greg McKaskle
Unread 24-01-2010, 22:34
ideasrule's Avatar
FRC #0610 (Coyotes)
The DS is the Classmate, but tomorrow we'll try using another laptop as the DS and see how that works. As for development tools, we're using Java with Netbeans 6.8 on a separate laptop. I just press the "Run" button to run the code; as far as I know, that builds the project, deploys the code, reboots the cRIO, and listens for output from the cRIO.
Unread 24-01-2010, 22:38
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Try going to control panels, power options and set the laptop to "Always On". This will ensure the processor is running at 1.6GHz when plugged in. The factory pre-load has it set on Max Battery which causes reduced performance even when plugged in.
Unread 24-01-2010, 23:16
It seemed as though some teams were fast user switching and leaving both accounts logged on. That seemed to cause pretty big lags for vision.
Greg McKaskle
Unread 25-01-2010, 13:56
ideasrule's Avatar
FRC #0610 (Coyotes)
OK, here's what I just tried:
Setting battery options to "Always On".
Running the driver station software under the Developer account.
Running the software with the Dashboard selected.
Logging on to only one account at a time.
Using a laptop as the driver station.
Setting the camera's frame rate to 5 frames/sec.
None of the above had an appreciable effect on the lag. Help!
Unread 25-01-2010, 14:00
TheDominis TheDominis is offline
FRC #2152
TheDominis has a spectacular aura aboutTheDominis has a spectacular aura about
Increase FPS? I don't know what you mean by lag. You are only going to get a new image every 200ms at that speed....
Unread 25-01-2010, 14:59
ideasrule's Avatar
FRC #0610 (Coyotes)
The problem is that I'm NOT getting one frame every 200 ms. I'm getting one frame every 500 ms. If I were getting 5fps, I'd be happy.
Unread 25-01-2010, 18:29
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
Well, we found *a* problem. We had been using the driver account on the ClassMate as the driver station, silly us, of course it's not designed for that exact purpose. When we logged off the driver account and switched to the developer account, the frame rate jumped up by a factor of ten or twenty (on 320x240 resolution), and the lag all but disappeared. What worries us now is we don't know whether this will be allowed at the competition (looked through the competition documents). Does anyone else have this problem and/or have a solution, or know if the Developer account will be allowed for use at the competition?
Unread 25-01-2010, 19:33
ideasrule's Avatar
FRC #0610 (Coyotes)
The story behind this is interesting. Patrick suggested using the developer account to test the camera feed. By chance, I was busy doing something and couldn't tell him he was being stupid because I'd already tried that (which I did). By chance, I had changed the image resolution from 640x480 to 320x240. Against all odds, these two unlikely events happened at the same time and led to our strange discovery. (I changed the resolution back to 640x480 and the lag time became the familiar 1/2 s.)
Another possibly useful piece of info is that I was using the code to test the frame rate by measuring the time it took to get 300 fresh images. We got 5 fps on 640x480, 21 fps on 320x240, and 30 fps on 160x120. However, the live feed was certainly not operating at 5 fps at a resolution of 640x480, regardless of the account used. It always operated at 2 fps.
Unread 25-01-2010, 22:06
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
We can confirm the behaviour that 610 is seeing. We get about 2 fps on the DS display, but there is a delay on top of that. The frames update at 2fps, but the frames we see are also more than 1s in the past. We notice this poor performance in the Driver account, even with 160x120 resolution frames.
Strangely, increasing the resolution does not seem to slow the framerates on the DS. In some cases the DS display updated faster on 640x480 than on 160x120.
However, the rate in which the cRIO processed the image was considerably faster with the small resolution.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 26-01-2010, 04:33
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Is the lag and frame rate in your system impacted at all by running wired vs. wireless?
Unread 26-01-2010, 13:20
FRC #2152
2 FPS is consistent with my benchmarks over in the C++ forums.
http://www.chiefdelphi.com/forums/sh...ad.php?t=80591
Yet Another Axis Camera Live Feed Issue z2daj FRC Control System 2 24-01-2010 13:47
Live Feed with Axis Camera CHSboy Programming 6 24-03-2009 14:43
2009 - Live camera feed to drivers during a match? Travis Hoffman Rules/Strategy 23 21-01-2009 17:43
Getting Live Feed from Axis Camera in Windriver Inoperational C/C++ 8 15-01-2009 01:21
live feed? miop Programming 1 02-02-2008 21:24
