Go to Post While you look at it as punishment, I look at it as a challenge. - Daniel_LaFleur [more]
Unread 24-01-2010, 23:24
remulasce remulasce is offline
remulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to behold
Driver station can't find io module
The problem is that when I try to connect the io station to our control laptop, it cannot find the io station. We have downloaded the v2 code to the iostation, but the driver station cannot find the io station on either the driver station netbook or a different laptop. The service that is supposed to be running is running, and a green light is lit on the iostation, so we have power. Any ideas on how to fix this?
Unread 24-01-2010, 23:34
Gary.C Gary.C is offline
OUTWORK US
FRC #1323 (MadTown Robotics)
Gary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond repute
Send a message via AIM to Gary.C
Re: Driver station can't find io module
Run the DS Update again and when it pops up what to install remove the cypress components and then let it finish. Then run the DS Update again and have it install the cypress components. It should appear in the driver station after that.
Gary Chahal
Webmaster & Sales Representative, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 25-01-2010, 01:24
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
Are you plugging into the USB hub? And if so, are other devices on the hub working?
We discovered a few days ago that the RED USb plug on the hub is only for power. If this is the only one connected, nothing will work even though stuff will light up.
Get yer robot source code here!
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 10-01-2010 15:04
Can't change team # (was: Driver Station problem) Lilszamora FRC Control System 2 03-02-2009 16:26
Can't find frame generator xrabohrok Inventor 2 14-01-2008 16:11
Can't find .h files pmzq Programming 2 24-01-2006 01:03
Can't find CD? Trinora 3D Animation and Competition 2 10-01-2004 14:47
