Go to Post And, by the way, we're all weird. It's just a matter of how well you hide or show it. :D - Billfred [more]
Unread 25-01-2010, 01:24
RoboTigers1796 RoboTigers1796 is offline
FRC #1796 (RoboTigers)
RoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of light
Re: pic: Team 1480 Kicker plumbing
i am... very confused. Anyone care to explain what's going on here?
2014 Attended: NYC Regional, SBPLI Regional NYC Regional- Imagery Award in honor of Jack Kamen
2013 Attended: NYC Regional, SBPLI Regional, FIRST Championships NYC Regional- Gracious Professionalism Award sponsored by Johnson & Johnson,SBPLI Regional- #4 Alliance Captain & Regional Winner- With our impeccable alliance 358 and 3171
2012 Attended: NYC Regional, SBPLI Regional, FIRST Championships NYC Regional- #7 Ranked Seed & Semi-Finalists, SBPLI Regional- #3 Seed & Regional Winner- With our very awesome alliance 527 and 870, Industrial Design Award sponsored by General Motors
2011 Attended: NYC Regional, SBPLI Regional SPBLI Regional- Xerox Creativity Award and #5 Alliance Captain
2009 Attended: NYC Regional, FIRST Championships NYC Regional Winner- With our amazing alliance 1807 and 56
Unread 25-01-2010, 01:34
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
I'm pretty sure I understand the diagram, but here's what I don't get:
If the solenoid valve is limiting your flow, then how is that changed by placing 60 PSI tanks after one valve, but before another valve? Doesn't the second valve limit the flow to the same as what you would have had without the tanks and second valve added to the system?
Unread 25-01-2010, 01:49
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Are you able to fully discharge your system using only the Parker pressure vent plug valve, as required by <R79>?
Unread 25-01-2010, 06:58
Enigma's puzzle's Avatar
Enigma's puzzle Enigma's puzzle is offline
Strategery
AKA: Matt Brechting
FRC #2075 (Enigma)
Enigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to behold
A ha, you are setting up a pneumatic spring, our team looked into it, its a way to get the energy from your pneumatics quicker. Since the pnuematics is only going to give you so much energy, delivering it quicker is your only chance to take a longer shot with the pnuematics.
Unread 25-01-2010, 09:35
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
I apologize, I should have added more explanation.
Our kicker operates by initially being latched back. The 60 psi storage "box" is one of the storage tanks. When the kicker is latched back the green arrows indicate the solenoid alignment, which allows the partially retracted cylinder to be precharged to 60 psi. To kick, the latch is released.
During retraction the solenoids are aligned to the red arrows.
Solenoid#2 is connected via brass fittings to the 60 psi storage and the kick cylinder. Solenoid #2 is added to conserve air that would otherwise be lost during retraction, minimizing recharge time for the next kick.
We may drop #2 if it looks like flow will be restricted too much.
Solenoid #3 is added to change kick distance by throttling the discharge rate. The "FAST" throttle valve is really schematic, since that won't be throttled at all. Note that on this valve inlet pressure is coming from the cylinder discharge. This is necessary in order to switch valve positions. (The solenoids don't actually switch the valves, they just open small pilot valves that allow air pressure to switch the valves).
The entire system is can be depressurized with a manual valve.
pic: Team 935 kicker teaser #1 railerobotics Extra Discussion 6 23-01-2010 12:15
pic: Team 1501 Kicker Wayne Doenges Extra Discussion 5 23-01-2010 08:05
Plumbing with Vex ManicMechanic VEX 0 28-09-2007 00:53
pic: Team 1501's shooter...errr kicker Wayne Doenges Robot Showcase 9 14-02-2006 14:44
