Re: Magnetic Lock
Are these automotive locks or building locks, and just out of curiosity, who uses just magnets. Most of the locks I know of use motors of some type, and some ones from the 40's through 60's use either vacum or hydraulics...but them I'm dating myself.
Re: Magnetic Lock
http://www.maglocks.com/magnetic_locking.htm Key cards instead of keys. Full audit trail of entry and exit. Battery backup for power fail. Security system locks and unlocks on programmed schedule. |
Re: Magnetic Lock
John,
Please ask the question on the Q&A. It will make the job of your inspector a little easier. In the past, if the magnet part attracted(moved) another part, it was considered to be a solenoid and not legal. If you are thinking of using this for a mechanism that would lock you into a hang position then remember that the robot is disabled at the end of the match and power to the device would be removed. |
Re: Magnetic Lock
Re: Magnetic Lock
It is legal for that specific use, provided that it doesn't violate other rules. |
Re: Magnetic Lock
Ether,
Your proposal is still difficult to rule on without seeing it during inspection and/or through a series of tests of the various rules under which it's use might be covered. The Q&A cites specifically R02 and R03 but I don't see anything in those rules that might apply. It would still need to be fed with a spike (if less than 20 amps) or speed controller, an appropriate sized breaker through the PD and be used with appropriately sized wire for the current it uses during operation. |
#7
Re: Magnetic Lock
yeah i know of a few teams in 2008 that used it to hurlde the ball and i think that tyou can use them as large as you can get rid of the energy at the end of the match.
| Magnetic Reed Switches... | Transformers | Pneumatics | 5 | 17-02-2007 01:12 |
| Magnetic Fields? | Robostang 548 | Electrical | 2 | 05-02-2007 08:42 |
| Magnetic Sensor on Pistons(help) | DPPT1717 | Pneumatics | 10 | 12-01-2007 12:00 |
| Magnetic Flux | Keith Chester | Math and Science | 3 | 11-04-2005 09:35 |
| magnetic sensor | Justin_302 | Electrical | 5 | 22-02-2005 13:32 |
