Go to Post It's a good things we're engineers who regularly squeeze out 'miracles' with a severely limited budget, eh? I think that's an important aspect that we as mentors need to show the students from time to time, and this year is a perfect opportunity. - JesseK [more]
Unread 23-01-2010, 10:01
Johnboi_117 Johnboi_117 is offline
FRC #2474
Johnboi_117 is an unknown quantity at this point
Magnetic Lock
Are magnetic locks legal, or are there rules against using them?
John, 2474
Unread 23-01-2010, 10:08
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Magnetic Lock
Is that like an electromagnetic solenoid? If so then it the rule book mentions it.
http://www.chiefdelphi.com/forums/sh...ad.php?t=79928
has more info.
Unread 23-01-2010, 10:27
FRC #2474
Re: Magnetic Lock
No, there is no solenoid involed. Its just an electric magnetic lock. Like what they use to lock doors.
John, 2474
Unread 23-01-2010, 10:35
MrForbes's Avatar
AKA: Jim
Re: Magnetic Lock
It is an electromagnet, right?
I didn't see anything in the rules about electromagnets, so perhaps you could ask on the Q&A. Since solenoids are prohibited, and an electromagnet is half a solenoid, it might not be allowed. Apparently they were allowed in 2008.
Unread 23-01-2010, 11:14
FRC #2474
Re: Magnetic Lock
Ok thanks, I'll do some more research.
Unread 23-01-2010, 14:36
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Magnetic Lock
This Q&A may be pertinent:
http://forums.usfirst.org/showthread.php?t=13979
Unread 25-01-2010, 02:45
mikeleslie mikeleslie is offline
FRC #1189
mikeleslie will become famous soon enough
Re: Magnetic Lock
Are these automotive locks or building locks, and just out of curiosity, who uses just magnets. Most of the locks I know of use motors of some type, and some ones from the 40's through 60's use either vacum or hydraulics...but them I'm dating myself.
Unread 25-01-2010, 03:32
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
Re: Magnetic Lock
We used locks like these for years with no break-in problems.
http://www.maglocks.com/magnetic_locking.htm
Key cards instead of keys. Full audit trail of entry and exit. Battery backup for power fail. Security system locks and unlocks on programmed schedule.
Unread 25-01-2010, 08:18
Re: Magnetic Lock
John,
Please ask the question on the Q&A. It will make the job of your inspector a little easier. In the past, if the magnet part attracted(moved) another part, it was considered to be a solenoid and not legal. If you are thinking of using this for a mechanism that would lock you into a hang position then remember that the robot is disabled at the end of the match and power to the device would be removed.
Unread 25-01-2010, 10:23
Re: Magnetic Lock
... if the magnet part attracted(moved) another part, it was considered to be a solenoid and not legal
what if it just held another part in place, once that part had already moved into position via some other force.
Unread 25-01-2010, 10:32
Re: Magnetic Lock
The Q&A has ruled. http://forums.usfirst.org/showthread.php?t=14093
It is legal for that specific use, provided that it doesn't violate other rules.
Unread 25-01-2010, 11:17
Re: Magnetic Lock
Ether,
Your proposal is still difficult to rule on without seeing it during inspection and/or through a series of tests of the various rules under which it's use might be covered. The Q&A cites specifically R02 and R03 but I don't see anything in those rules that might apply. It would still need to be fed with a spike (if less than 20 amps) or speed controller, an appropriate sized breaker through the PD and be used with appropriately sized wire for the current it uses during operation.
Unread 25-01-2010, 12:50
carbuff2228's Avatar
carbuff2228 carbuff2228 is offline
Scouting Mentor -College student
FRC #2228 (Cougartech)
Team Role: Scout
carbuff2228 is on a distinguished road
Re: Magnetic Lock
yeah i know of a few teams in 2008 that used it to hurlde the ball and i think that tyou can use them as large as you can get rid of the energy at the end of the match.
Magnetic Reed Switches... Transformers Pneumatics 5 17-02-2007 01:12
Magnetic Fields? Robostang 548 Electrical 2 05-02-2007 08:42
Magnetic Sensor on Pistons(help) DPPT1717 Pneumatics 10 12-01-2007 12:00
Magnetic Flux Keith Chester Math and Science 3 11-04-2005 09:35
magnetic sensor Justin_302 Electrical 5 22-02-2005 13:32
