Go to Post I challenge the status quo - it's just me. - techhelpbb [more]
Unread 23-01-2010, 19:35
WildBill's Avatar
WildBill WildBill is offline
FRC #2845 (O'Botics)
WildBill is an unknown quantity at this point
Arrow Octagon
Our team was considering a modified octagon design. We have not had any luck searching for pre-made 135 degree brackets. We do not know all of the suppliers - mainly look at AndyMark and google search. If there is any senior teams that know a possible supplier we would be happy to receive advice.
Unread 23-01-2010, 19:59
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Octagon
80-20 has a 6 hole 45 degree that should work. But it may be faster/cheaper to cut & drill aluminum plate.
Or cut the kit chasis down in size for the 'rectangles', and 1x1 aluminum square tube (available at Lowes & Home Depot) will fit inside the kit 'C' channel for the angles.
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Octagon
Are you looking to use the Kit chassis rails?
I think the Corner Connect's in the kits can turn at such an angle, look at the omni kit chassis, it looks like they are turning at 45 degrees there. You could probably get it to work. You could always make a plate of aluminum to turn the corner, and put it on the top and bottom, attached with two bolts to each piece. You might need to face some of the angled pieces with the C facing out instead of in, to get the Corner Connects to work.
Kettering Motorsports
Unread 23-01-2010, 22:09
NickE's Avatar
NickE NickE is offline
_
Re: Octagon
http://www.8020.net/Quick-Frame-13.asp
Unread 25-01-2010, 10:50
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Octagon
The set your own angle brackets here might work out: http://www.mcmaster.com/#catalog/116/2991/=5j274g
Unread 25-01-2010, 20:13
WildBill's Avatar
Re: Octagon
Thanks for the suggestions, we will take a look into them.
