Go to Post Good thing you skipped this year. You don't need exhaustion to sleep through Recycle Rush. - Gregor [more]
Unread 25-01-2010, 12:07
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
Re: Some Camera Benchmarks
Just to give some comparison benchmarks, I did some testing In LabVIEW. With compression set to 5, here are the loop rates I got:
640x480 image: loop rate = 8 per second avg
320x240 image: loop rate = 10 per second avg
160x120 image: loop rate = 13 per second avg
This might at least give you an idea of what you should be able to shoot for. A couple of other observations. With compression set to 0, loop rates suffered (expected). Increasing the compression above 5, didn't seem to improve loop rates, but it did affect the ability to find the target.
<G14> - ya win some, ya lose some GaryVoshol Rules/Strategy 62 24-03-2009 16:22
Some Questions ggberg Rules/Strategy 8 09-01-2008 16:51
Tell the difference: 2007 CMU Camera, 2006, 2005 camera? Chris_Elston Programming 2 07-01-2008 13:11
Camera Help (New to Camera Programming) Idaman323 Programming 6 14-01-2006 03:56
