Go to Post "No wheels, no problem, we can fix it in programming." - clean399 [more]
Unread 24-01-2010, 17:27
gyaniv's Avatar
gyaniv gyaniv is offline
AKA: Gutman Yaniv
FRC #2230 (General Angels)
gyaniv has a spectacular aura aboutgyaniv has a spectacular aura about
Clutch system
Does anyone know if a 12v clutch is allowed on the robot?
or even 5-6v if the is one that exist.
FRC Team 2230 - Student - 2009-2011
FRC Team 2230 & 4406 - Mentor - 2012
FRC Team 2230 - Mentor - 2013-present
"A mentor's job is to understand what the students are trying to make, and bend the laws of physics to make that happen"
Unread 24-01-2010, 17:45
Re: Clutch system
No other electrically operated motor or actuator, than what's called out explictly by the rules, is allowed.
So, no.
Last edited by Mark McLeod : 24-01-2010 at 18:52. Reason: Okay Jim, I admit my wording is terribly sloppy :)
Unread 24-01-2010, 17:48
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Clutch system
I expect he is asking about an electromagnetic clutch? of the type used on air conditioning compressors in cars. If so it would likely fall into the "electromechanical actuator" category and be illegal. Or not....
Unread 24-01-2010, 19:22
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Clutch system
Here is the appropriate Q&A:
http://forums.usfirst.org/showthread.php?t=13981
Unread 24-01-2010, 20:03
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
Re: Clutch system
Originally Posted by Vikesrock View Post
I don't really think that this answers all the questions. Why? Cause my team is trying to figure out if we can use a clutch that we used in 2008 for our catapault and we're not getting any specific answers yet.
http://forums.usfirst.org/showthread.php?t=13980
I'm not psychic GDC, just give me a straight answer. I can't determine if x part is legal if I don't know what the official definition of this is.
-Tanner *confused*
Unread 24-01-2010, 23:59
Re: Clutch system
The web page pointed to in that Q&A specifically describes an electric solenoid valve actuator. It has components that aren't part of a generic solenoid.
The "official definition" of an electric solenoid actuator is pretty simple and reasonably obvious. A solenoid consists of an electromagnet and an armature that moves to provide a mechanical output when the electromagnet is energized.
If you tell us what "x" is, many of us will be able to tell you why it is or is not legal according to the robot rules.
Unread 25-01-2010, 08:30
Re: Clutch system
Tanner,
This is the section that applies to your answer...
<R53> Items specifically PROHIBITED from use on the ROBOT include:
A. Electric motors and/or servos different from, or in addition to, those in the KOP, with the exception of those specifically permitted by Rule <R52>.
B. Electric solenoid actuators (note: electric solenoid actuators are NOT the same as pneumatic solenoid valves – the latter are permitted, the former are not).
If you had an electric clutch that used a moving part that was attracted by a magnetic field, then this rule would have applied in 2008 and would (should) have been deemed illegal as it is in 2010. The same language existed in the rules then as now. If you would like to PM me with the part you are considering I can give you an opinion from an inspector point of view. The definitive answer still comes from the GDC via the Q&A and has been answered.
Unread 25-01-2010, 11:59
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Clutch system
Doesn't the definition of "solenoid" also necessarily specify that the electromagnetic coil produces a reasonably uniform magnetic field in the centre of the coil, and that the armature is located there? (Otherwise, there would be no distinction between a run-of-the-mill electromagnet, and a solenoid.)
Considering that distinction, I'm not convinced that an electromagnetic clutch is always illegal—it would depend on what's inside. Given this question and its response, I think the GDC is agreeing in general terms with that proposition.
Unread 25-01-2010, 12:04
MrForbes's Avatar
AKA: Jim
Re: Clutch system
If there is an armature that moves in response to the electromagnet being energized, it's probably a solenoid and illegal. If nothing moves as a result of the electromagnet being energized, it's probably just an electromagnet and legal.
We still haven't seen pictures of the device in question, so it's pretty hard to say.
An electromagnetic clutch used in an automotive air conditioning compressor has a part that moves as a result of energizing the electromagnet, so it's probably a solenoid.
If there is some other type of electromagnetic clutch, I'd like to see it.
Unread 25-01-2010, 12:13
Re: Clutch system
Just for the sake of discussion, is this electromagnetic bell a prohibited solenoid actuator? (I would say no, because its geometry is inconsistent with a solenoid.)
From Wikimedia Commons
Unread 25-01-2010, 12:26
Re: Clutch system
There are clutches that use a magnetorheological fluid which changes its viscosity based on an applied magnetic field.
Unread 25-01-2010, 12:29
Re: Clutch system
I would expect the GDC to rule it illegal. The geometry might be inconsistent with the typical electric solenoid actuator, but the action is close enough that I think it meets the intent of the prohibition.
Unread 25-01-2010, 12:33
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Clutch system
There are clutches that work off of magneto-strictive (sp?) materials like Terfenol-D
___________________
- Tennyson, Ulysses
Unread 25-01-2010, 12:45
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: Clutch system
-Tanner *confused*
Tanner,
After examining your 2008 bot at GA Tech at the control system demo last year, several of us spent much discussion on your clutch, and the legality thereof. We came to the conclusion that the inspectors overlooked an apparent violation. This was just our opinion, we have no line into the mysterious hive mind of the GDC.
I agree that the Q&A answers have been vague, but it looks to me like they are saying that if something moves by electromagnetism, and it's not part of a solenoid valve, or a motor provided in the kit, then it is illegal. I realize that the movement in the clutch is very small, but if they intended to allow some movement, they would have specified a maximum. By not doing so, they specified a maximum of zero inches.
All of the above is my opinion, and has no real meaning in the greater scheme of FIRST.
Former Mentor Team 1771
Former mentor Team 4509
Unread 25-01-2010, 13:06
MrForbes's Avatar
AKA: Jim
Re: Clutch system
This type of clutch would probably be prohibited too, as it contains a liquid.
ELECTRONIC CLUTCH? xc4life Electrical 1 09-02-2009 16:35
Bosch clutch/reducers? kaszeta Motors 1 28-01-2005 14:55
Drill Motor Clutch GrahamS314 Motors 2 22-02-2004 01:05
Driving a clutch Kevin A Chit-Chat 18 03-07-2003 16:02
Locking the clutch Joe P Motors 12 01-03-2003 21:17
