Go to Post My experience in FIRST has taught me that, whatever you do, make sure that no single failure can eliminate half your drive system.[...] The worst feeling in the world is having your robot driving around in circles when there is critical business to be done on the playing field. - Andrew [more]
Unread 25-01-2010, 13:01
CaptainMorton CaptainMorton is offline
FRC #0888
CaptainMorton is an unknown quantity at this point
USB Hub Doesnt want to be found
We were testing out a new input that we added to the I/O board and then noticed the stop button wasnt attached. We attached the stop button to the USB Hub and then promptly got the Blue Screen of Death.
Then we restarted the computer and tried again, without the stop button attached just in case, but the I/O board and the joysticks were not being seen. We plugged the I/O board directly into the Classmate and it showed that it was connected.
We restarted the computer and the problem continued.
Do you think that the USB Hub is beyond fixing or is there something else we should try to get it working again?
Unread 25-01-2010, 14:13
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Re: USB Hub Doesnt want to be found
We ran in to a very similar problem with a faulty USB hub from the KOP. If you read the reviews for that product on Amazon you will probably be amazed at how many other people have had reliability issues with that hub. It is probably worth investing is a more reliable one.
Good luck!
Rob
Unread 25-01-2010, 16:28
Do you have the red USB power cable from the hub plugged in as well?
It may just be that the hub doesn't have enough power to drive the devices plugged into it, and the red power cable can help that.
Unread 25-01-2010, 17:59
skeltech skeltech is offline
FRC #1468
skeltech is an unknown quantity at this point
Connect the Black USB HUB on the left USB connector on the 2goPC and the Cyrpess Board to the right USB connector on the 2goPC.
A USB connector on a PC will provide 500 ma of power. We are OK with 3 joysticks and the E-Stop button on the hub using one of the 2goPC USB ports.
Unread 26-01-2010, 11:01
SteveD SteveD is offline
FRC #0888
SteveD is an unknown quantity at this point
Yes, our hub doesn't work with any computer, but the little light comes on. even with the power cord attached it did nothing. we tried another hub that we had an it worked.
USB Hub Defective samcorp Kit & Additional Hardware 24 25-02-2010 13:15
away around the USB chicklet for using USB Controllers Stobei Programming 2 26-01-2008 14:27
Gameport to Usb cable vrs. Usb Chicklet haywirerobotics Control System 4 25-01-2007 19:03
Plastic hub parts source found A_2 Kit & Additional Hardware 0 15-01-2005 11:23
USB to Serial -- Working Device Found! Eko Programming 10 23-02-2004 12:56
