Go to Post Joe is a great sport and this was a good moral booster after a grueling weekend. How many opportunities do you get to play William Tell with a Regional WFA Winner? :) - The Lucas [more]
Unread 25-01-2010, 12:36
Addicted2FIRST Addicted2FIRST is offline
FRC #0442
Addicted2FIRST is an unknown quantity at this point
Programming data to be sent to the Dashboard
Hi, Everyone.
Has anyone figured out how to successfully send data to the dashboard. I've looked at all the posts concerning this topic and looked at the examples. The examples aren't commented well and the posts just seem to send me in circles.
Does anyone have a sample code I could look at or point me to the MOST EFFICIENT topic to solve this problem?
Thanks in advance for any and all help!
Unread 25-01-2010, 15:07
sircedric4's Avatar
sircedric4 sircedric4 is offline
AKA: Darren
no team (The SS Prometheus)
sircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond repute
Re: Programming data to be sent to the Dashboard
Originally Posted by Addicted2FIRST View Post
Hi, Everyone.
Depends on the type of data you are looking to send. I've run into problems getting both types of "standard" data to the dashboard.
If you are looking to get the standard default dashboard to update the PWM, solenoid, analog etc... readouts then you need to read this topic:
http://www.chiefdelphi.com/forums/sh...ad.php?t=80526
The key to getting the Dashboard example to work is to know that it isn't useable out of the box. Some code needs to be uncommented, and then you have to be careful how fast you call the associated functions.
If you are wanting to send other data of your own choosing to the User Input section of the dashboard then you need the first 3 posts from this topic:
http://www.chiefdelphi.com/forums/sh...ad.php?t=80802
You can use the WPI User Guide to some extent though it could definitely use some page numbers, hyperlinks, and bookmarks. It's a good start but I still find I've got to post questions here as well like you. :-)
Bunch of good people here, so hopefully if I didn't get you answered to your satisfaction, someone else can.
Unread 25-01-2010, 15:50
FRC #0442
Thanks for your help and advice. I'm getting a second wind (more like 23rd wind) so I'll be really looking more in depth on this.
LabVIEW Video Tutorial: Customizing The FRC Dashboard To See Your Data LVMastery NI LabVIEW 0 10-02-2009 13:50
Serial data out of the programming port Doug Leppard Programming 5 07-04-2008 08:53
Dashboard, The Comp and sensor data... Kevin Karan Programming 7 28-01-2004 21:31
dashboard data stream archiver 2000 10 23-06-2002 22:56
Additional Dashboard Data Curtis Williams Programming 3 08-02-2002 15:25
