Re: Pit Area?
Eagle
The size of the pits may not be determined until a more complete team list is in place. I believe you are coming to Chicago, Midwest Regional. If you get lucky, an end pit allows a little extra breathing room but plan on 8 ft. x 8 ft. and be pleasantly surprised if it is larger. If you need anything, send me PM. I will be your Lead Inspector in Chicago. |
Re: Pit Area?
The pits are about 3 x 3 meters, perhaps a little bigger or smaller. I thought I would add the metric measurement, too, if that makes more sense for you.
Re: Pit Area?
Thanks, metric measurement is better for us =)
Re: Pit Area?
It all depends on the regional. Most are about 10 x 10. At the Florida regoinal we have had more room (it seemed like more) and at the Philadelphia regional we've had as little as 7 x 8 (you never know what to expect there).
Re: Pit Area?
Also depends on the year and venue. 2008 L.A. Regional shared space with the water tank for American Gladiators. Pits were pretty small (I think 8' by 8'). 2009 L.A. Regional was in a new venue with plenty of room. Teams were pleasantly surprised to find 10' by 15' pits with wide aisles.
Re: Pit Area?
Usually depending on the amount of registered teams and size of the venue. Its anywhere from 8x8 to 12x12 generally speaking. but just check your regional and if there is around 35-40 anticipate a larger pit and so on and so forth.
#7
Re: Pit Area?
I would also like to add that you are also limited to 10' in height as well. I remember last year one team had to modify their pit structure to comply with that rule.
#8
Re: Pit Area?
| The pit area | tongsui | General Forum | 1 | 26-01-2009 21:39 |
| your pit area | zakattacks99 | General Forum | 29 | 14-01-2008 07:11 |
| Construction of pit area | Macdaddy549 | General Forum | 1 | 16-07-2005 15:20 |
| Pit Area Assignments | greenz_gurl15 | Championship Event | 5 | 20-04-2002 13:44 |
| Crates in pit area | mnkysp6353 | General Forum | 10 | 25-01-2002 06:22 |
