Programming data to be sent to the Dashboard
Hi, Everyone.
Has anyone figured out how to successfully send data to the dashboard. I've looked at all the posts concerning this topic and looked at the examples. The examples aren't commented well and the posts just seem to send me in circles. Does anyone have a sample code I could look at or point me to the MOST EFFICIENT topic to solve this problem? Thanks in advance for any and all help! |
Re: Programming data to be sent to the Dashboard
If you are looking to get the standard default dashboard to update the PWM, solenoid, analog etc... readouts then you need to read this topic: http://www.chiefdelphi.com/forums/sh...ad.php?t=80526 The key to getting the Dashboard example to work is to know that it isn't useable out of the box. Some code needs to be uncommented, and then you have to be careful how fast you call the associated functions. If you are wanting to send other data of your own choosing to the User Input section of the dashboard then you need the first 3 posts from this topic: http://www.chiefdelphi.com/forums/sh...ad.php?t=80802 You can use the WPI User Guide to some extent though it could definitely use some page numbers, hyperlinks, and bookmarks. It's a good start but I still find I've got to post questions here as well like you. :-) Bunch of good people here, so hopefully if I didn't get you answered to your satisfaction, someone else can. |
Thanks for your help and advice. I'm getting a second wind (more like 23rd wind) so I'll be really looking more in depth on this.
| LabVIEW Video Tutorial: Customizing The FRC Dashboard To See Your Data | LVMastery | NI LabVIEW | 0 | 02-10-2009 01:50 PM |
| Serial data out of the programming port | Doug Leppard | Programming | 5 | 04-07-2008 08:53 AM |
| Dashboard, The Comp and sensor data... | Kevin Karan | Programming | 7 | 01-28-2004 09:31 PM |
| dashboard data stream | archiver | 2000 | 10 | 06-23-2002 10:56 PM |
| Additional Dashboard Data | Curtis Williams | Programming | 3 | 02-08-2002 03:25 PM |
