Go to Post ...never do something because it is comfortable, do something because you WANT to do it. - Andrew Schreiber [more]
Unread 25-01-2010, 16:13
ForeverNight ForeverNight is offline
FRC #2526
ForeverNight is an unknown quantity at this point
Testing Relays
So, we broke 3 of our 5 relays last year and, like idiots, forgot to label or throw away the broken ones. Now, as head of electrics I've inherited this problem from last year's team, so my question to you all is, how do you test these things?
The only ideas I've had to test them so far are: A) Hooking them up to a pair of power sources (1 to plug in on the input side, 1 to hook up to the pwm cables to simulate data) and then taking a multi-meter to record voltage. or B) Pluging it in to our current test bed w/ cRIO and digital side car and then testing for continuity.
So, is there any good way for this to be tested? Nobody has any ideas on my team and those are the ideas I've posted. So, basically, help?
Unread 25-01-2010, 16:16
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Testing Relays
If you have a test bed already set up with a cRIO and Digital Sidecar can't you wire the Spikes up to a motor one at a time and test them? The Spikes use spade terminals so you do the wiring once and then just switch the Spikes in and out.
Also, were the Spikes themselves fried or did you just blow the fuses?
Unread 25-01-2010, 16:19
Re: Testing Relays
Use a simple program on the cRIO to control a relay output. Wire that relay output to the suspect Spike along with power. Either put lights or motors on the Spike outputs, or just measure the output voltage with a DVM.
Unread 25-01-2010, 16:21
FRC #2526
Re: Testing Relays
Alright, I was thinking that that was the best option available, but the testbed is being dominated by our programmers. So I was wondering if there was another way. Ah well, thanks.
Yes, we fried the spikes. I don't know how we did it, but we did. I did some work with them last year and replaced the fuses, but still didn't work. Thanks, I'll get going on testing them.
Unread 25-01-2010, 16:40
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Testing Relays
I believe you can hook it up to a standard R/C receiver, and use a standard R/C transmitter to make them go.
The easiest ways to blow up a spike are to reverse the input power, or to hook the battery to the outputs.
Unfortunately, the spade design makes it easy to do either of those.
Calculating relays. VEN Electrical 3 24-04-2007 22:23
Motors, Relays, Rules.... Xeilos Technical Discussion 5 16-02-2006 07:42
Programming relays railerobotics Programming 2 03-02-2006 15:00
2004 spike relays sweet-chan Electrical 2 07-02-2005 02:14
SPIKE relays Andy Brockway Electrical 2 13-11-2002 13:22
