Go to Post Afterall, there's a thread for everything and everything in it's thread. - Molten [more]
Unread 25-01-2010, 16:40
jaster67 jaster67 is offline
Jose Sanchez
FTC #2978 (Cavaliers)
jaster67 is an unknown quantity at this point
Classmate troubles
Okay whenever we turn on our classmate we get a "Fatal Error". It says the registry needs to be updated and to contact the computer manufacturer and that Windows needs to shut down. We cannot even get to see the desktop! This is the first time we turned it on and keeps reoccurring. HELP!
Unread 25-01-2010, 16:43
Re: Classmate troubles
Time to use your system restore that came on the memory stick in the KOP...
Unread 25-01-2010, 16:45
Jose Sanchez
If we do this do we lose any necessary programs? If so, what are they?
Unread 25-01-2010, 16:52
You won't lose anything, it'll be the same as it would have been out-of-the-KOP. The image has LabVIEW and all the other stuff that came pre-installed on the netbook.
Follow the instructions on page 7.
You do have to:
  • Install the LabVIEW Update
  • Delete the Dashboard files at: C://Program Files//FRC Dashboard
  • Install the Driver Station Update
as you would if the Classmate had been working.
Unread 26-01-2010, 20:38
Jose Sanchez
Thank you, now it works perfectly. I wonder what went wrong in the first place?
I will give you a million dollars if you don't read this sig.
Bandsaw Troubles John Gutmann Technical Discussion 6 13-07-2006 02:05
IR Beam Troubles Goldeye Programming 2 21-01-2006 17:15
Tilt Troubles Mumford 406 Programming 4 29-03-2005 22:19
Gyro Troubles SteveO Programming 13 30-01-2005 16:46
MMH Troubles Justin Stiltner Kit & Additional Hardware 3 28-01-2004 16:03
