Go to Post Edison was once asked "how do you come up so many good ideas?" to which he responded "for every good idea, I have 99 bad ideas first." - dlavery [more]
Unread 25-01-2010, 18:06
Sauce Sauce is offline
FRC #1245 (Shazbots)
Sauce is an unknown quantity at this point
Incorporating Tank Drive
Our team has edited Teleop.vi to use tank drive, opening the second joystick, reading Y axes and closing the joysticks. Two of the 4 jaguars recieved signal but didn't change upon moving the joysticks.
screenshot of the code attached. Sorry I didn't clean it up. I tried to but it made it look completely illegible.
Unread 25-01-2010, 18:21
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Incorporating Tank Drive
Did you open Begin.VI and change the Open 2 Motor VI to an Open 4 Motor VI?
Also, you will want to open the second joystick in Begin.VI instead of inside the case statement in Teleop. Look at the code that is already there for an example of how to open the Joystick then store it as a refnum.
Then in Teleop.VI you would need to put a Refnum Registry Get.VI from the Joystick section on the outside of the case statement (looks very similar to the icon already there for Drive.)
Someone else may be able to explain this in a more elegant manner if you're still having trouble.
Unread 25-01-2010, 19:29
alright thanks, got it working
Unread 25-01-2010, 20:11
It's a good thing the Joystick Close vi doesn't really do much. You definitely shouldn't have it in the Teleop vi. It, along with all the other Close vis should go in the Finish vi.
Tank Drive vs. Omni Directional Drive jamie_1930 General Forum 9 24-01-2010 22:50
Tank Drive Code? huskyrobotics NI LabVIEW 9 16-02-2009 22:04
Tank Drive Sauce Programming 1 05-01-2009 18:50
Tank Drive Idaman323 Programming 14 15-02-2005 09:01
tank drive Stormhammer Programming 11 29-01-2004 23:08
