Thread Tools |
Rating:
Display Modes |
Re: Position Control using potentiometer?
The jaguar does not blink any lights, and does not respond to either PWM, or CAN enumerate. |
Firmware for Black Jaguar is "BlackJaguar-87.bin" and the firmware for (Gray) Jaguar is "Jaguar-87.bin". There is a way to recover by using BDC-COMM in the command line. Open up a command line terminal and navigate to the folder where you have bdc-comm.exe. To make it easy you can put it in your 'c' drive. I also recommend putting the firmware files in the same folder as bdc-comm.exe so that you do not have to type in a file path. In the command line run the following: 1) C:>bdc-comm.exe -c N - replace the 'N' with the COM port number you are using 2) # id X - replace 'X' with the ID you had previously set for that Jaguar (factory default is 1) 3) # update BlackJaguar-87.bin - if the firmware is in the same folder as bdc-comm.exe, this will work. Be sure to change the file name for Gray Jaguar firmware. The update should happen, showing progress as a percentage. Hopefully if everything went OK your Jaguar should be blinking again. -David |
Thank you for the help, I will try the position control again tomorrow. |
Doh! I'll let you know when this is fixed!
The files are correct now:
BlackJaguar-87.bin -> Black Jaguar MDL-BDC24 firmware Jaguar-87.bin -> (Gray) Jaguar MDL_BDC firmware |
| Using the cRIO to control custom lights | hal_2498 | FRC Control System | 14 | 10-04-2009 07:55 |
| Using a pot to control speed | SL8 | NI LabVIEW | 13 | 18-02-2009 17:02 |
| Potentiometer arm control | Hazmatt | Programming | 15 | 01-04-2008 21:27 |
| Using a computer to control the pic | mikesown | Programming | 6 | 13-09-2005 19:13 |
| Using a switch to control a PWM | Max Lobovsky | Programming | 11 | 25-02-2004 17:20 |
