Go to Post CIMs are NEAR indestructible and I <3 them for it. - Andrew Schreiber [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 25-01-2010, 22:12
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Re: Position Control using potentiometer?
Originally Posted by dyanoshak View Post
This can happen if you loaded (Gray) Jaguar code on a Black Jaguar and vice versa.
Firmware for Black Jaguar is "BlackJaguar-87.bin" and the firmware for (Gray) Jaguar is "Jaguar-87.bin".
There is a way to recover by using BDC-COMM in the command line.
Open up a command line terminal and navigate to the folder where you have bdc-comm.exe. To make it easy you can put it in your 'c' drive. I also recommend putting the firmware files in the same folder as bdc-comm.exe so that you do not have to type in a file path.
In the command line run the following:
1)
C:>bdc-comm.exe -c N
- replace the 'N' with the COM port number you are using
2)
# id X
- replace 'X' with the ID you had previously set for that Jaguar (factory default is 1)
3)
# update BlackJaguar-87.bin
- if the firmware is in the same folder as bdc-comm.exe, this will work. Be sure to change the file name for Gray Jaguar firmware.
The update should happen, showing progress as a percentage. Hopefully if everything went OK your Jaguar should be blinking again.
-David
The files seem to be miss named, the BlackJaguar-87.bin file worked on a grey Jaguar, but the Jaguar-87.bin file caused it to crash.
Thank you for the help, I will try the position control again tomorrow.
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 25-01-2010, 22:54
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Doh! I'll let you know when this is fixed!
Unread 26-01-2010, 10:53
AKA: David Yanoshak
The files are correct now:
BlackJaguar-87.bin -> Black Jaguar MDL-BDC24 firmware
Jaguar-87.bin -> (Gray) Jaguar MDL_BDC firmware
Using the cRIO to control custom lights hal_2498 FRC Control System 14 10-04-2009 07:55
Using a pot to control speed SL8 NI LabVIEW 13 18-02-2009 17:02
Potentiometer arm control Hazmatt Programming 15 01-04-2008 21:27
Using a computer to control the pic mikesown Programming 6 13-09-2005 19:13
Using a switch to control a PWM Max Lobovsky Programming 11 25-02-2004 17:20
