Re: Announcing: GRTFramework from team 192
Cheers to implementing and async mvc.
I do have a few comments about the architecture. here's my ideas summed up into bullets -models would contain a list of all the components (specific actuators, mechanisms...) -controllers would always talk through commands -view (robot) would register models on the fly and controllers would get them using the abstract factory pattern with explanation: First off the MainRobot class contains a RobotBase however it does not interact with the mech directly, but rather through the controller. Thus it is my belief that the MainRobot should not contain the RobotBase but rather it should be responsible for registering the RobotBase with the controller, (which it already does, but as it contains the base too it is a little confusing) Also with regards to the model, it does not look like you really implement a model per se. The easiest way to think of the model is as a database. So for each type of key object(ie mechanisms, actuators, sensors...) you would have a factory that contains these and is able to product the specific model you want based on how the robot registers (take a look at the abstract factory pattern) and finally with regard to the async, which is awesome! however it is only implemented for the actuators. I believe that the same should be done for anything that has a model, and definitely for the mechanisms. In a prior season back when we were still using C our team implemented an architecture using a maneuver-mechanism-actuator structure. Your async design would build upon this allowing for the robot to queue up mechanism based maneuvers (ie raise arm, drive forward) and these maneuvers would work separately from each other. Personally I think every time a controller is used it should use the command system you've set up. I know this is a lot to take in and I hope it was some help |
| Team 192, Robot Lifting Teaser | Joobacca | Robot Showcase | 7 | 02-02-2007 17:46 |
| Sync Magainze article about Gunn Robotics Team ... Do adults ruin the game? GRT 192 | ducttapejason | FIRST In the News... | 2 | 10-08-2005 08:45 |
| Team 192 Animation submission | Rysith | 3D Animation and Competition | 6 | 02-03-2004 13:08 |
| Thanks to Team 34 and Team 192 | Mike Henry | Thanks and/or Congrats | 0 | 17-03-2002 21:58 |
