Go to Post Dave Lavery was right... all we had to do was type in "attack old lady" and when we started up our robot it did. - Human Player [more]
Unread 25-01-2010, 23:23
tutkows1's Avatar
tutkows1 tutkows1 is offline
FRC #2077
tutkows1 is an unknown quantity at this point
Question Camera Lag
I'm having a hard time reducing the amount of lag i get from live camera feed. I have tried messing with compression and resolution but i still have like a 5 secound lag.
The following code, writen in Java, is the example dashboard code with camera feed added, i put my additions, camera feed code, in blue.
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.AnalogModule;
import edu.wpi.first.wpilibj.Dashboard;
import edu.wpi.first.wpilibj.DigitalModule;
import edu.wpi.first.wpilibj.DriverStation;
import edu.wpi.first.wpilibj.DriverStationLCD;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.Solenoid;
import edu.wpi.first.wpilibj.Watchdog;
import edu.wpi.first.wpilibj.camera.AxisCamera;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the IterativeRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
/*This Dashboard example has been modified to
* output camera feed on the driver station
* --Mark Tutkowski--
public class DashBoardExample extends IterativeRobot {
* This function is run when the robot is first started up and should be
* used for any initialization code.
public void robotInit() {
AxisCamera.getInstance().writeResolution(AxisCamer a.ResolutionT.k160x120);
AxisCamera.getInstance().writeBrightness(0);
Watchdog.getInstance().setEnabled(false);
* This function is called periodically during autonomous
public void autonomousPeriodic() {
//Update Camera Feed
DriverStationLCD.getInstance().updateLCD();
* This function is called periodically during operator control
public void teleopPeriodic() {
updateDashboard();
Theres a little bit more code but the rest of it is not related to the camera.
Is there anyway to reduce the lag.
Unread 27-01-2010, 00:20
ideasrule's Avatar
ideasrule ideasrule is offline
FRC #0610 (Coyotes)
ideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the rough
Re: Camera Lag
Try this:
http://www.chiefdelphi.com/forums/sh...ad.php?t=81058
2010 FRC Camera Live Feed Lag ideasrule Programming 23 11-02-2010 02:33
Camera Lag jmanela NI LabVIEW 6 25-12-2009 08:48
Teleop Lag Xavier Brandall Programming 14 17-03-2009 18:21
Lag Much? Caldwell_D Technical Discussion 2 09-11-2008 11:46
Lag Issue bizarospooky Programming 7 08-02-2008 17:31
