Go to Post I have postulated a theory that it is due to a resonance between gravity waves and the color purple. - petek [more]
Unread 25-01-2010, 18:27
ideasrule's Avatar
ideasrule ideasrule is offline
FRC #0610 (Coyotes)
ideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the rough
Dashboard indicators
I know this might be a stupid question, but how do you use the various displays on the dashboard? How do you make the gyro update the compass heading, for example? I can get the camera feed, but nothing else.
BTW, I'm using Java on NetBeans 6.8. Attached is a photo indicating which portions aren't working.
Unread 25-01-2010, 22:27
Re: Dashboard indicators
The dashboard is tied to robot I/O. The sample code assumes that you've mounted the gyro and attached it to channel one on module one.
Greg McKaskle
Unread 25-01-2010, 23:26
Have you looked at the Circle Tracker Demo project?
Unread 26-01-2010, 06:53
sircedric4's Avatar
sircedric4 sircedric4 is offline
AKA: Darren
no team (The SS Prometheus)
sircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond repute
You also need to be careful and check that the code which polls the various other devices on the cRio like the PWM's, digital I/O and analog I/O are not commented out.
I don't know if java is the same but when I was working this issue with C++, most of the code that would actually make the dashboard read the cRIO positions was commented out for us and replaced with arbitrary constants.
[Poll] Does your launcher use "armed" indicators? Rick General Forum 13 26-02-2008 21:39
Labview Dashboard and updated IFI dashboard spec Joe Ross LabView and Data Acquisition 1 04-04-2006 02:04
2004 Dashboard Protocal vs 2005 Dashboard Protocal Kyle T Programming 4 14-03-2005 22:19
Pneumatics Limit Indicators yaman Programming 5 03-02-2003 01:54
Indicators archiver 2001 1 24-06-2002 00:03
