Go to Post It's still not about the robots. FIRST is about doing the right thing. - DonRotolo [more]
Unread 25-01-2010, 23:34
maniac_2040's Avatar
maniac_2040 maniac_2040 is offline
AKA: Matt
FRC #3302 (Turbo Trojans)
maniac_2040 is infamous around these partsmaniac_2040 is infamous around these partsmaniac_2040 is infamous around these partsmaniac_2040 is infamous around these parts
Send a message via MSN to maniac_2040
Wireless Bridge Disconnects when driving?
Our team has been having an issue with the cRIO disconnecting while attempting to drive. Not sure if there is a problem with the wireless bridge or not, but basically everything works okay(able to download code and run it) when we connect the classmate directly to the cRIO. However, when we connect the cRIO to the wireless bridge, the wireless bridge to the router, and our classmate to the router, our code runs until we attempt to drive and then summarily disconnects after 2-3 seconds. It then does not reconnect until we completely restart the robot. One interesting thing is that it ONLY disconnects when attempting to drive. If the code does not send any pwm outputs, there are no problems.
Any idea what could be causing this?
Thanks in advance!
Unread 25-01-2010, 23:39
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Wireless Bridge Disconnects when driving?
Is the wireless bridge connected to the dedicated 12V port at the end of the Power Distribution board and not to a regular breaker?
Unread 25-01-2010, 23:43
Zorkinian Zorkinian is offline
AKA: John Gilbert
FRC #0488 (Xbot)
Zorkinian is on a distinguished road
Yeah, last year before we connected the bridge to dedicated power we noticed that every once in a while the bridge would reset. We were confused until we realized that it was correlated with low battery voltage.
What was happening was that large current draws (like drive motors) were causing voltage to drop down below 6V, which was essentially a brownout for the bridge.
Unread 26-01-2010, 07:32
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
We were getting this with dead batteries. If we drove very slow and never accelerated hard, then we could move, but as soon as we did anything that would cause a voltage spike, the robot would disconnect (we'd loss comms on the classmate) and the jaguars would show a slow red blink, which is a jaguar fault code.
Are your jaguars giving you a slow red blink when the robot disconnects? If so, that's more evidence that your voltages get too low when driving.
Unread 26-01-2010, 08:44
When the bridge is connected to the PD normal outputs and not the dedicated outputs, the battery voltage drops when ever a motor starts or reverses. That is why the dedicated output is required. The PD has an internal boost buck regulator designed specifically for this purpose. The wireless has another problem though. It was not designed to be attached to a moving object and as such has a vibration sensitive power connector and a delicate ethernet connector. Teams should be careful to use wire ties to take the strain and vibration of the these cables so that the vibration doesn't cause noise in the connectors. If you move the power connector and it seems loose, the second contact in the connector is likely out of alignment or you have replaced the power connector with the wrong size part. The power connector should have a firm feel and should provide some resistance to pullout. If it does not, check that the connector is the right size. It that appears correct, the connector on the bridge may be damaged.
Unread 26-01-2010, 09:03
sloteera's Avatar
sloteera sloteera is offline
AKA: Rafa
FRC #1860 (Cephatron)
sloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud of
Exceptional explanation Al.
Thank you for share the information about the internal Boost Buck regulator on PD!!
Unread 26-01-2010, 10:46
Darkknight512 Darkknight512 is offline
Programmer/Electronics
FRC #3375 (North Stars)
Darkknight512 is on a distinguished road
Is it possible that the regulator doesn't react fast enough and the bridge reboots? My team is having the same problem I will try and secure the connections in the mean time.
Another note that might support the vibration/shock idea, when we drove up the ram and fell down the robot disconnected. (Fell from half way to the top of the ramp)
Unread 26-01-2010, 11:04
I have not seen the regulators fail to keep up with voltage variations. I would suspect that this is a very well designed circuit and should be able to keep up with almost anything. It has a 4.5 volt dropout but the Crio will disable outputs if the battery voltage falls below 5.5 volts. Of course, the Crio is using the 12 volt jumper on the analog module to sense the battery voltage. The fall in all likely hood damaged the internal connector on the bridge.
Unread 26-01-2010, 16:31
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
Originally Posted by maniac_2040 View Post
Our team has been having an issue with the cRIO disconnecting while attempting to drive. Not sure if there is a problem with the wireless bridge or not, but basically everything works okay(able to download code and run it) when we connect the classmate directly to the cRIO...
Thanks in advance!
You say that you have problems when trying to drive. Have you tried putting the robot on blocks and driving under little to no load? If this fixes the problem, it could be an electrical issue. If it doesn't, maybe you have some sort of code instantiation problem? Have you tried looking at the diagnostic messages being sent out by the cRio using the NetConsole?
- Bryce
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Wireless Bridge Problems furiousgeorge Control System 9 28-01-2010 13:28
Help connecting wireless bridge cactuarman Control System 4 24-03-2009 14:24
Wireless bridge not allowing IP change Lord Byron FRC Control System 6 15-01-2009 17:55
Source for Wireless Bridge Gary Bonner FRC Control System 1 07-01-2009 20:57
Wireless Bridge to Nowhere(Help Please!) TeknicllyInsane General Forum 3 11-12-2008 22:40
