Re: Spinning the Robot with Mecanum Wheels
Here's a question: if you mount your wheels in a square configuration (ie, your wheelbase = your track), is it possible to rotate your bot about center?
(...unless you have your wheels swapped, in which case it won't be able to rotate itself at all.) |
This seems to be unconventional thinking, and I can't seem to find anywhere on CD that this has ever been stated. Am I missing something? Would anyone be willing to provide a vector analysis of a square 'bot rotating about center? (It can be done using four identical wheels, but thats not what I'm after. Two "RH" and two "LH" wheels, mounted in an "O" configuration, cannot seem to create a moment about the center of a square bot). |
The front left wheel will be pulling forward and to the right. The rear left wheel will be pulling forward and to the left. The front right wheel will be pulling backward and to the right. The rear right wheel will be pulling backward and to the left. So, all 8 force vectors are pulling CLOCKWISE. The vectors do not cancel, they add. So the bot spins clockwise. ~ |
Specifically, I believe that when you're summing moments (R x F) you are forgetting to include make R negative in one direction.
the pronoun "you" is ambiguous. which post were you responding to? craigboez or me? ~ |
#7
Sorry about the ambiguity. |
#8
Take a look at this PDF: http://lib.store.yahoo.net/lib/yhst-...lSpecSheet.pdf It has a force-vector diagram and complete explanation for all three degrees of freedom: fwd/rev, slide left/right, spin CW/CCW To spin in place clockwise, wheels 1 and 3 should be driven forward while wheels 2 and 4 are being driven backward. If you do this, the force vectors on each of the 4 wheels will produce torque moments about the center of the wheel pattern all in the clockwise direction. They do not cancel, they add. ~ |
#9
If your wheel configuration looks like an "O" when viewed from the TOP, it is not the correct configuration, and the bot will not spin properly. For those of you new to this discussion, here's what we mean by "X" and "O" configurations: "X" configuration: \..../ ...... ...... /....\ "O" configuration: /....\ ....... ....... \..../ ~ |
#10
Thanks to all for your input. The fact that the wheels, when viewed from above are different from the wheels when viewed from below was the big aha! moment here. Thanks especially to Ether for the in depth explanation - I have now seen the light.
#11
It is kind of funny because now that I understand the problem I see the answer posted in many places.
#12
The O is the way to go...
I have been lurking on this thread for a while, but I kept quiet because I didn't really have anything worth adding... ...until now. When this issue was first introduced in my mind as a potential problem, I had to think about which way I would orient the wheels if nobody told me the answer and I hadn't yet done the experiment. Sadly, I got it wrong. My first thought was to say that I wanted the wheels on the ground in the X position. My reasoning went like this: I wanted the small wheels oriented such that it would make it easy to spin the robot about its center. An X seems to provide this feature. And it is true as far as it goes -- if you have the wheels in an X configuration and you lock the main axle of the wheels (i.e. turn the motors off), you should be able to spin the robot about its center fairly easily. BUT... ...then I thought, "What is going to provide that spinning force?" Well... ...it is SUPPOSED to be the motors driving the main axles of the wheels, of course. BUT, the way Mecanums work is that they only apply force to the ground in the direction of the axles of those little wheels (the same can be said for holonomic wheels, by the way). Now that X configuration is a disaster because all the wheel force vectors go right through the center (or very near the center) of the robot! Torque is force times moment arm: Small moment arms => small torques. Even if the wheels are putting out largish traction forces, that force is multiplied by as small moment arm. The net result is a robot that has issues spinning about its center. So... when it comes to Mecanums the O is the way to go. Cheers, Joe J. Last edited by Joe Johnson : 26-01-2010 at 14:35. |
#13
What powerpoint did you use. could you post a link?
| 2481 Drives Over the Bump with Mecanum Wheels | kylelanman | Robot Showcase | 13 | 02-02-2010 00:53 |
| Holonomic drive vi with mecanum wheels | dwodrich | NI LabVIEW | 7 | 18-01-2010 16:01 |
| Help with mecanum wheels | CyDrive | Programming | 7 | 10-02-2008 16:16 |
| Assistance with Mecanum Wheels | CollmandosGrl | General Forum | 8 | 14-01-2008 17:42 |
| Teams With Mecanum Wheels | Foss@Team176 | Technical Discussion | 15 | 06-10-2005 09:38 |
