Go to Post Javelins, armadillos, and rhubarb pie haven't been used as game pieces yet, either. Just sayin'. - Travis Hoffman [more]
Unread 25-01-2010, 18:42
Teammax's Avatar
Teammax Teammax is offline
30 Members 6 Weeks 1 Dream
AKA: Rob Cormier
FRC #1071 (Team MAX)
Teammax is just really niceTeammax is just really niceTeammax is just really niceTeammax is just really nice
Spinning the Robot with Mecanum Wheels
We are having major problems getting the robot to spin with mecanum wheels. I beleive the code is correct as we consulted a power point from here that verifies our program matches the work of others.
The robot goes forward, backward. side to side, and at an angle just fine. But, when we try to spin it the robot just vibrates a lot. We did try putting wieght on the wheels. Has anyone else had this problem? Any fixes the might work?
Thanks in advance
PS if there is an old thread that addresses this issue I didnt find it and would be happy to go there if this was covered
Unread 25-01-2010, 18:44
spacewolfx's Avatar
spacewolfx spacewolfx is offline
Gear Box
FRC #3176 (Purple Precision)
spacewolfx will become famous soon enoughspacewolfx will become famous soon enough
Re: Spinning the Robot with Mecanum Wheels
could it be that your COG is off by an uneven distribution of weight?
Unread 25-01-2010, 18:47
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
The problem is almost certainly the setup of the wheels. There is one setup of mecanum wheels that works right and one setup that behaves as described. I don't remember what the appropriate way to swap the wheels is to get them into the right setup, but I'm sure someone will be by shortly who does know.
Unread 25-01-2010, 18:56
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
If you were to draw an imaginary line with the roller axes as they look from a top-down view, the lines should make an 'X'. More than likely, yours make an 'O'.
You want the 'O' on the bottom, not the top.
Another symptom of this is that it may be difficult to maintain a straight line when going diagonally.
GitHub
Unread 25-01-2010, 19:32
Teammax's Avatar
AKA: Rob Cormier
There was some discussion about this X vs. O but I am going to check our alingment now with what you said. Thanks a lot guys
Unread 25-01-2010, 20:36
Thanks in advance
http://www.chiefdelphi.com/forums/sh...ad.php?t=80962
http://www.chiefdelphi.com/forums/sh...ad.php?t=80490
http://forums.usfirst.org/showthread.php?t=14135
Unread 25-01-2010, 20:37
Teammax's Avatar
AKA: Rob Cormier
We are defintely in the wrong alignment and I have guys changing to the X alignment now. You guys have really saved us a lot of time because the next few 'tests' we were going to try would have taken a lot longer to do.
Unread 25-01-2010, 22:00
End for end OR side for side. Or just flip the frame over, if it's low enough...
Unread 25-01-2010, 23:00
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Thanks, I'll try and remember that. That was what I thought, but I didn't really want to guess and have them switch them and it still be wrong.
Unread 26-01-2010, 00:42
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Here's a question: if you mount your wheels in a square configuration (ie, your wheelbase = your track), is it possible to rotate your bot about center?
Unread 26-01-2010, 01:12
Yes. It'll actually work best that way.
(...unless you have your wheels swapped, in which case it won't be able to rotate itself at all.)
Unread 26-01-2010, 02:38
craigboez's Avatar
Mechanical Engineer
For wheels mounted in the correct configuration, I don't think that it's possible to rotate a bot about center if they are mounted in a square configuration. When summing moments about center they all cancel out when length = width. Only when you have a rectangular bot, where length != width, can you create one pair of moments not offset by the other pair.
This seems to be unconventional thinking, and I can't seem to find anywhere on CD that this has ever been stated. Am I missing something? Would anyone be willing to provide a vector analysis of a square 'bot rotating about center?
(It can be done using four identical wheels, but thats not what I'm after. Two "RH" and two "LH" wheels, mounted in an "O" configuration, cannot seem to create a moment about the center of a square bot).
Unread 26-01-2010, 11:04
Consider a bot with 4 mecanum wheels mounted so that they have the "X" configuration when viewed from the top. Now drive both wheels on the left side forward, and both wheels on the right side backward, all at the same speed.
The front left wheel will be pulling forward and to the right. The rear left wheel will be pulling forward and to the left. The front right wheel will be pulling backward and to the right. The rear right wheel will be pulling backward and to the left. So, all 8 force vectors are pulling CLOCKWISE. The vectors do not cancel, they add. So the bot spins clockwise.
Unread 26-01-2010, 11:13
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Specifically, I believe that when you're summing moments (R x F) you are forgetting to include make R negative in one direction.
Unread 26-01-2010, 11:26
Hi Matt,
the pronoun "you" is ambiguous.
which post were you responding to? craigboez or me?
2481 Drives Over the Bump with Mecanum Wheels kylelanman Robot Showcase 13 02-02-2010 00:53
Holonomic drive vi with mecanum wheels dwodrich NI LabVIEW 7 18-01-2010 16:01
Help with mecanum wheels CyDrive Programming 7 10-02-2008 16:16
Assistance with Mecanum Wheels CollmandosGrl General Forum 8 14-01-2008 17:42
Teams With Mecanum Wheels Foss@Team176 Technical Discussion 15 06-10-2005 09:38
