Go to Post Oh... and congratulations FIRST, for launching the biggest shinny object of distraction just days before FRC kick-off. ;) - Michael Sperber [more]
Unread 25-01-2010, 19:46
jimwick's Avatar
jimwick jimwick is offline
jim wick
FRC #0885 (the Green Team)
jimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of light
mounting Fisher Price transmissions
We may be using Fisher Price motor transmissions for one of our tasks, namely setting a ball shooter.
Has anyone had experience in mounting these transmissions? They don't seem to have any good mounting lugs or mounting holes.
If we modify the transmissions by drilling mounting holes, is that a violation of the rules about modifying motors?
Any experience about this will be of great interest to us.
Jim Wick
sorry, too old, too ugly for a photo
Unread 25-01-2010, 20:17
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Re: mounting Fisher Price transmissions
These two pictures show how we mounted the transmission in 2008. Don't mind the messy wiring -- we cleaned it up later
http://picasaweb.google.com/quixilve...49444474043890
http://picasaweb.google.com/quixilve...49461653913090
EDIT: Besides the one screw holding the transmissions on, there is also two clamps, kind of like how parts are clamped to milling machines.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 25-01-2010, 21:31
ShaneP's Avatar
ShaneP ShaneP is offline
Lead Mentor
FRC #0330 (The Beach Bots)
ShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to behold
We mount the fisher price transmissions which control our arms in a similar fashion.
The shaft they turn keeps them in place, locked up against the square tubing (in our case, 1.5"x1"). Shaft collars keep the transmissions from sliding out (off the shaft).
To turn the shaft (1/8" keyway shaft), we machine an octagon hub/block that picks up the octagon shape of the inside of the fisher price output. The hub is then bored to the shaft diameter and an 1/8" keyway is broached.
Hose clamps are used to hold the white plastic output of the fisher price transmission to the octagon hub to avoid slippage.
Last edited by ShaneP : 26-01-2010 at 13:54. Reason: not hex, i meant octagon, my mistake
Unread 25-01-2010, 22:41
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Originally Posted by ShaneP View Post
To turn the shaft (1/8" keyway shaft), we machine a hex hub/block that picks up the hex shape of the inside of the fisher price output. The hub is then bored to the shaft diameter and an 1/8" keyway is broached. .
Isn't that output piece a octagon?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 25-01-2010, 22:55
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
It is an octagon.
"we don't build robots, we build people"
Unread 26-01-2010, 01:44
And if we don't have a vertical member that will work in the right place, it's pretty easy to turn some plate aluminum of reasonable thickness and some angle aluminum into a pair of mounting brackets.
1) Cut the plate to shape. You'll probably want some form of triangle. Note: Helps to have at least one side exactly the same.
2) Locate and drill a hole for the axle. Try to get it in the same place on both plates.
3) Attach the angle aluminum to the plates.
4) If more weight is needed elsewhere, leave about 1/2 inch all around the edge of the plates and the holes in them. Remove excess material inside that as needed.
We did that in 2004 for a winch system similar to the one Eugene posted. Started using handy vertical frame members in 2005, when they weren't moving relative to the base of the robot.
Unread 26-01-2010, 12:54
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
You can modify the gearbox any way you want. You cannot modify the actual motor.
I'm thinking about removing the gears and mounting them between two plates (like an AndyMark Toughbox).
Ed Sparks
MECH TECH FRC-3959
Unread 26-01-2010, 13:25
CrazyCarl461's Avatar
CrazyCarl461 CrazyCarl461 is offline
Power User
AKA: Carl Agnew
CrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant future
Send a message via AIM to CrazyCarl461
We do that every once in a while and it works pretty well for us, especially when we want to cut out the final stage and output from the second-to-last gear. If you use an open plate design, be ready for a really loud, whiny gearbox.
My 2011 Build Season Blog
Resistance may be futile, but capacitance has potential!
© All content is protected by the honor system
Unread 26-01-2010, 16:23
jimwick's Avatar
jim wick
Thanks everyone for replying to my original post. The information is very helpful. I'm always amazed and pleased at the good will among the FIRST teams.
Jim Wick
HELP! Looking for Fisher-Price Mounting Screws Graham Donaldson Motors 2 04-12-2008 14:15
fisher price Futbol.195 Electrical 8 20-01-2008 16:47
Mounting Fisher Price Gearboxes Bochek Technical Discussion 8 09-02-2007 16:34
Mounting / Connecting The Fisher Price Motor Xufer Motors 21 31-01-2006 20:16
Fisher Price Motor Mounting Ashley Weed Motors 1 16-02-2003 19:29
