Go to Post Go figure that by teaching you end up learning a lot through the process. ;) - Josh Fox [more]
Unread 26-01-2010, 02:38
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Re: Spinning the Robot with Mecanum Wheels
Originally Posted by Alan Anderson View Post
Yes. It'll actually work best that way.
(...unless you have your wheels swapped, in which case it won't be able to rotate itself at all.)
For wheels mounted in the correct configuration, I don't think that it's possible to rotate a bot about center if they are mounted in a square configuration. When summing moments about center they all cancel out when length = width. Only when you have a rectangular bot, where length != width, can you create one pair of moments not offset by the other pair.
This seems to be unconventional thinking, and I can't seem to find anywhere on CD that this has ever been stated. Am I missing something? Would anyone be willing to provide a vector analysis of a square 'bot rotating about center?
(It can be done using four identical wheels, but thats not what I'm after. Two "RH" and two "LH" wheels, mounted in an "O" configuration, cannot seem to create a moment about the center of a square bot).
2481 Drives Over the Bump with Mecanum Wheels kylelanman Robot Showcase 13 02-02-2010 00:53
Holonomic drive vi with mecanum wheels dwodrich NI LabVIEW 7 18-01-2010 16:01
Help with mecanum wheels CyDrive Programming 7 10-02-2008 16:16
Assistance with Mecanum Wheels CollmandosGrl General Forum 8 14-01-2008 17:42
Teams With Mecanum Wheels Foss@Team176 Technical Discussion 15 06-10-2005 09:38
