Go to Post FIRST needs a disclaimer that parts of the field can become flying projectiles under hurricane force winds. - Barry Bonzack [more]
Unread 26-01-2010, 04:12
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Robot Main.vi
Originally Posted by elmer_fud View Post
If you start developing your own framework you have to make sure to do things like set up the watchdog and driver station properly. If you don't set up the watchdog properly you could run into problems with the robot not running or not stopping when you press the E-stop button. If you E-stop button doesn't work correctly I think you would be disqualified for safety reasons.
If you don't set up the watchdog correctly, you may not be able to get your robot to drive, but it can always be E-Stopped. There is a separate watchdog that teams have no control over that responds to the E-Stop command. Nothing you can screw up in your code will make it fail to E-Stop.
Basic Robot Main vi chinckley NI LabVIEW 7 03-03-2009 15:54
Using Robot Main LiLFiL Programming 1 14-02-2009 18:51
Coordinating Robot Main VI with Autonomous VI jjauss Programming 2 07-02-2009 09:26
Dashboard and Robot main with Axis camera Team2883 General Forum 9 10-01-2009 07:35
main.c 6600gt Programming 3 29-08-2006 02:19
