Go to Post The scent of a smoking Globe motor is familiar to many. - Alan Anderson [more]
Unread 25-01-2010, 19:33
flyvin flyvin is offline
FRC #0095
flyvin is an unknown quantity at this point
Flashing cRIO
I tried flashing the cRIO with v19 today, and it did it with no problem. Then I tried re-running the code that had been working before, but it had an error. This is what is said:
[cRIO] FPGA Software Revision: 1.3.0
[cRIO] * Loading StartupDlls: FRC_JavaVM
[cRIO] Warning: module 0x1348318 (FRC_JavaVM.out) holds reference to undefined symbol _ZN5nFPGA33nE0037A37F5C5D7F6A40E3C03D3CE51DD8tCounter23readTimerOutput_StalledEPi.
[cRIO] Warning: module 0x1348318 (FRC_JavaVM.out) holds reference to undefined symbol _ZN5nFPGA33nE0037A37F5C5D7F6A40E3C03D3CE51DD8tCounter11strobeResetEPi.
[cRIO] Warning: module 0x1348318 (FRC_JavaVM.out) holds reference to undefined symbol _ZN5nFPGA33nE0037A37F5C5D7F6A40E3C03D3CE51DD8tCounter36writeConfig_DownSource_AnalogTriggerEbPi
... (alot more warnings like this) ...
[cRIO] Warning: module 0x1348318 (FRC_JavaVM.out) holds reference to undefined symbol _ZN5nFPGA33nE0037A37F5C5D7F6A40E3C03D3CE51DD4tDIO16writePulseLengthEhPi.
[cRIO] (unloading partially loaded module FRC_JavaVM.out)
[cRIO] ...FRC_JavaVM failed to load.
[cRIO] task 0x1d871f8 (t2) deleted: errno=0 (0) status=0 (0)
[cRIO]
[cRIO] Welcome to LabVIEW Real-Time 8.6.1f2
[cRIO]
[cRIO] NI-VISA Server 4.5 started successfully.
[cRIO] task 0xe62018 (t1) deleted: errno=1835009 (0x1c0001) status=1 (0x1)
I have tried re-installing the image a few times, but with no result. I will try to re- download it tonight, because the room that were building at has bad internet. Please help.
Unread 25-01-2010, 19:37
ideasrule's Avatar
ideasrule ideasrule is offline
FRC #0610 (Coyotes)
ideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the rough
Re: Flashing cRIO
Did you install the Labview update on the computer you're using to program? Also, did you try creating a new project in Netbeans and copying your previous code over?
Unread 26-01-2010, 04:17
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Flashing cRIO
[cRIO]
[cRIO]
The problem is that you haven't updated your NetBeans plugin. Those errors happen when you deploy with an old VM.
Unread 27-01-2010, 08:19
FRC #0095
Re: Flashing cRIO
Thanks! I updated my netbeens plugin and now it works perfectly.
flashing orange Mac Generals Electrical 10 01-02-2009 11:18
Flashing compact rio? excel2474 Programming 3 06-01-2009 14:10
Code Flashing Issues bluenp Programming 4 07-11-2007 23:43
Flashing Battery Light Max Brin Technical Discussion 3 12-01-2006 11:46
flashing LEDs jacob_dilles Electrical 1 22-02-2004 21:52
