Go to Post However I did tell my wife I wanted to lose 20lbs of ugly fat quickly. She told me to cut off my head. Go figure. - Ed Coleman [more]
Unread 25-01-2010, 15:24
a kenny03 a kenny03 is offline
Robotics for life(stupid classmate)
AKA: PICKELL!!!
FRC #0219 (Team Impact)
a kenny03 is an unknown quantity at this point
Send a message via AIM to a kenny03
camera and console
anyone have any decent sample working code that can send images back to the driverstation?
and is there an acutal console like there was last year?
Unread 26-01-2010, 04:24
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: camera and console
I'm pretty sure there is an example for this.
What do you mean? Like the blue thing last year? The classmate is the new driver station. No more custom hardware.
Unread 26-01-2010, 18:26
nadavsen2 nadavsen2 is offline
FRC #2231
nadavsen2 is an unknown quantity at this point
I need to a simple code for deploying the image to the driverstation..
if there is a simple code can anyone tell me where its locate?
links? something?
Unread 26-01-2010, 21:32
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
If the camera and driver station machine are set up properly, you should only need a few lines of code to be able to see a feed from the camera. Top three things to confirm:
1) The camera has an FRC/FRC account added to it (see the control system documentation for details).
2) The driver station and dashboard have been PROPERLY updated. You may even have to fully delete the folders in program files and reinstall them.
3) The camera is connected via crossover cable to ethernet port 2 on the cRIO and the LEDs on the camera are green.
The code to include:
import edu.wpi.first.wpilibj.camera.AxisCamera;
AxisCamera.getInstance().writeResolution(AxisCamera.ResolutionT.k160x120);
AxisCamera.getInstance().writeBrightness(0);
Unread 26-01-2010, 21:47
ideasrule's Avatar
ideasrule ideasrule is offline
FRC #0610 (Coyotes)
ideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the rough
You could also load the CircleTrackerDemo example project (if you're using Java) or the "2010 FRC Vision Demonstration" if you're using Windriver.
Java/Netbeans Camera Code for Classmate PC and Axis Camera joshholat Programming 1 23-01-2010 14:59
Console output jrws C/C++ 4 21-01-2010 04:33
Default windriver program, no code and warnings on CRIO console out pafwl C/C++ 1 16-01-2010 16:03
PC versus Console Denman Chit-Chat 40 22-05-2005 18:01
