Go to Post ...when you hear a kid say "oink oink" and you say in your head "BOOM!" - delsaner [more]
Unread 01-26-2010, 07:24 AM
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Re: Cannot Mix C Code
But if you compile everything as C++, the symbols should match up and the linker should have no problem. I'd focus on just getting it to compile as C++. I don't know why this should be too much of a problem. If it's some some stupid persistent project setting that you can't change or something, try copying the code into new .cpp files.
Unread 01-26-2010, 07:46 AM
Jared Russell's Avatar
Taking a year (mostly) off
It seems that this is the simplest solution to this problem. Usually, the C/C++ mixing nastiness is only an issue if you are using a large C code base and/or pre-compiled C library that you want to link with in a C++ application. Since it seems like there is only a single C-style function, just rename it to .cpp and the compiler will compile it as C++.
As to what the problem may be with your current extern "C" way, what is a "scheme *" type defined as? Is it a C type or a C++ class? Consult this FAQ for more information.
Unread 01-27-2010, 01:12 PM
nabioullinr nabioullinr is offline
FRC #1073
nabioullinr has a spectacular aura aboutnabioullinr has a spectacular aura aboutnabioullinr has a spectacular aura about
Thanks! It works now.
I did not recognize at first that the source file was compiled separately; I wanted to have .c in order to convey the fact that it is a C source file, rather than a C++ class.
Unread 02-09-2010, 12:10 AM
FRC #1073
I'm now facing the same issue, but this time I cannot merely rename the source file to .cpp because it contains numerous implicit type conversions which are considered errors in C++. Manual typecasting will probably take a week. Maybe I should try calling from inline asm to avoid name mangling issues, or simply rename the C functions to the mangled name...not elegant but this might work.
Unread 02-09-2010, 11:51 AM
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Or just put the header include inside an extern "C".
Unread 02-09-2010, 03:24 PM
FRC #1073
That only works when the file has the extension .cpp (i.e., is compiled as C++).
Unread 02-09-2010, 03:26 PM
Exactly... so when you are including the C header file in a .cpp file, you include the header as extern "C".
Cannot deploy code Patrick Chiang FRC Control System 18 03-16-2013 03:46 PM
Cannot Download Code mandalorethx C/C++ 5 01-15-2010 12:44 PM
Cannot get Code to Download to cRIO greekgod8591 C/C++ 25 03-09-2009 10:10 PM
Cannot Download Code to our Robot jcvd C/C++ 9 01-27-2009 01:09 PM
