Go to Post The ideals that are held by myself and by many of the longtime FRC mentors and volunteers whom I consider friends and colleagues are bigger than FIRST, and we will find (or make) another vehicle for them if we are forced to. - Jared Russell [more]
Unread 22-01-2010, 20:55
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Cannot deploy code
We cannot deploy code to the robot. It works some of the time and fails most of the time. Pinging the bridge and cRIO gets reply at all times. Forum search is fruitless.
Our deployment window:
Initializing...
Calculating dependencies...
Checking items for conflicts. This operation could take a while...
Preparing items for download. This operation could take a while...
Deploying MotorControl.lvlib
Deploying 2010 Game Robot Project.lvproj
>>here, we get an alert: Waiting for Real-Time target (RT CompactRIO Target) to respond
>>With option: Stop Waiting and Disconnect
>>this does not go away, meaning cRIO never responded.
Deploying RT CompactRIO Target(failed to deploy target settings)
Deployment completed with errors
>>after we close the deployment window, we get alert:
Warning: Connection to the Real-Time Target has been lost.
Any subsequent attempts to deploy without rebooting the cRIO result in a conflict resolution window with message:
Access denied: This target is already in use by another project or host computer.
Rebooting the cRIO and retrying sometimes works and sometimes fail. Nothing seems to be different between the times that work and the times that don't.
Unread 22-01-2010, 23:56
Re: Cannot deploy code
Are you connecting your programming computer via a wired network or wireless? If wired, try turning off any other network interfaces (including a wireless adapter).
Unread 23-01-2010, 04:32
Does this occur when using a direct cable between computer and cRIO? Is it unique to the wifi setup?
Greg McKaskle
Unread 23-01-2010, 17:23
Programming
Both. Our first configuration was:
Laptop IP: 10.30.70.6
Wireless Router IP: 10.30.70.4 (gateway)
Robot Wifi IP: 10.30.70.1
cRIO IP: 10.30.70.2
Setup:
Laptop-(eth)->Router-(wifi)->Robot Wifi-->cRIO
Then, we tried Laptop-(eth)->cRIO, and the same thing occurs.
We've already updated our software to the latest version and flashed the cRIO afterwards. Would this have anything to do with using a computer other than the Classmate they gave us?
Thanks for your time!
EDIT: And yes, we do disabled other network interfaces. The problem is that pinging the target works 100% of the time, but deployment does not.
Unread 23-01-2010, 22:12
This message is common and should go away on it's own eventually.
Does it go away, or do you click "Stop Waiting and Disconnect?"
Unread 25-01-2010, 18:17
Programming
It never goes away. As in, we wait for a few minutes and the alert does not go away.
We've noticed something else too: This never happens on our first try, and a complete reboot of our computer, the robot, and our router fixes it, but we'd rather not have to reboot all our electronic equipment everytime we want to deploy code.
Unread 26-01-2010, 03:13
Merle Merle is offline
FRC Mentor, FLL Coach
FRC #3146 (GRUNTS)
Merle has a spectacular aura aboutMerle has a spectacular aura aboutMerle has a spectacular aura about
In the 'Create new FRC Robot Project' screen are you replacing the xx.yy values in the cRIO IP address field with your team numbers? I have found that if you forget to change those that you will get the error that you describe.
Merle Yoder
Mentor FRC 3146- The GRUNTS (Granby Robotics Under No Technical Supervision)
Coach FLL - Granby Red Blox - CT State 2nd place Champions Award
Unread 26-01-2010, 07:50
Good point. If you've already run the wizard, look at the project window to see if the cRIO target item has xx.yy or the team number. To change, right click on that line and choose properties.
Greg McKaskle
Unread 26-01-2010, 18:14
Programming
Problem is: it's not failing on us consistently, only some of the time, and the IP is pointed at the correct cRIO (10.30.70.2) in LabVIEW.
Unread 15-02-2010, 09:05
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
ONLY 1 week left and problems are arising!! We are having a similar problem. When i build the project it works. When i try to deploy it, it gives me : Access denied: The project may be in use by host computer..... BUT ONLY THE CLASS MATE IS CONNECTED. I tried restarting the classmate, the roobot, NOTHING WORKS. One other problem: when i try to "run as startup", when its almost fnished .. the connection is lost, and it DOES NOT GO AWAY!... Plz help only got 2 days to finish robot cause we have too many holidays next week ( about 3>!!!)
Unread 15-02-2010, 09:16
The next time you get that message "Access denied: The project may be in use by host computer..... ", try pushing the tiny Reset button on the cRIO itself. It's a little black depression next to the 24v power connection.
When you get the "Waiting for Real-Time target (RT CompactRIO Target) to respond" message and it stays around for more than a couple of minutes. Just cancel the download and try again.
You seem to be having an intermittent connection problem, possibly due to a noisy connection.
Unread 15-02-2010, 09:50
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
As a small aside,
Even though our team is using WindRiver, we've seen multiple times that what we originally thought was an intermittent network connection problem, was actually a power problem. Start from the battery, and give all power connections between the battery and the cRIO a quick shake to make sure they're tight. Especially check the cRIO 24V connectors to make sure you don't have too little or too much of the wire stripped and inserted into both ends of the screw terminals of the plug.
Secondly, we ran into intermittent communications problems after opening the cRIO and installing the gaskets provided this year. We ended up needing to remove them unfortunately. Once we did everything worked fine again. Opening the cRIO and blowing out any debris that might've accumulated from last year might help here.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 15-02-2010, 12:38
David Fort David Fort is offline
FRC #1001
David Fort is on a distinguished road
ok, I'm a little embarrassed to ask this, but could someone give me a hint how to deploy?
We did it last year with WindRiver, but haven't found the corresponding button in NetBeans yet.
(and are generally not having any luck with WindRiver or NetBeans this year).
If there is a place in one of the various "how to" guides, I'd be most grateful for a reference.
Thanks.
Team 1001
Unread 16-02-2010, 08:36
FRC #1514 (Vikings)
Thanks.
Team 1001
Try going on this website
http://netbeans.org/kb/docs/java/javase-intro.html
Sorry i am kinda in class so ill tell u full solution in couple of hours
Unread 17-02-2010, 15:40
Noamr Noamr is offline
FRC #1574 (Miscar)
Noamr is an unknown quantity at this point
We had the exact same problem (it would get stuck deploying the lvproj).
At first we could solve it by building and deploying the code (after that it ran fine).
At some point that also stopped working. Someone told us it might be because our flash code gets stuck doing some process. Anyway, we formatted, re-imaged the controller, ran super-simple code on it and now it's fine.
I think it might have gotten stuck because the enable vision was on and the camera wasn't connected. If I find out more about this I will post it here.
Hope this helps...Good luck!
Cannot Download Code mandalorethx C/C++ 5 15-01-2010 12:44
Cannot get Code to Download to cRIO greekgod8591 C/C++ 25 09-03-2009 22:10
unable to deploy SL8 NI LabVIEW 1 17-02-2009 21:02
Cannot Download Code to our Robot jcvd C/C++ 9 27-01-2009 13:09
