New Camera Class
BETA
I've heavily modified some camera code. There is slightly different functionality in smash_camera.cpp in GetJpegImageBlocking. It blocks with different functionality. It will not always succeed. You can change the functionality by copying the original method from PCVideoServer.cpp. Also, for now, you must manually set the IP to the computer to want to receive video from. You must do this in the method VideoServerHelper on line 65 in smash_video_server.cpp. Required Code: Code:
#include "smash_camera.h" smash::AxisCamera& camera = smash::AxisCamera::getInstance(); camera.writeResolution(smash::k160x120); camera.writeBrightness(0); I didn't try to 2Go PC, but I got 20+ FPS on 160x120. I'll upload dashboard later.... must go! Last edited by TheDominis : 26-01-2010 at 08:25. Reason: Upload Limit |
Re: New Camera Class
I'm sorry if I'm not getting this, but what does this do? Does it give an increased framerate or is it just designed to let the user customize what IP they want to use to receive video data?
Does this run on a LabVIEW dashboard, or some custom implementation of your own? |
I didn't know that the zip limit was greater than the rar format. It failed for that reason.
The Dashboard frame rates at 160x120 were 20+ on the laptop I tested it on (not the 2Go computer). The other formats were less, but I think that was due to an error in the dashboard. You will need 3.5 .NET Framework for this to work. Perhaps even SP1 for 3.5 .NET. Last edited by TheDominis : 26-01-2010 at 12:42. Reason: Requirements |
You still didn't really answer my question. Is this just a custom video dashboard? What advantages does this have over the standard code?
Opposed to the stock camera server, my server gets 20+ FPS at 160x120. Other image sizes are slightly buggy, but I'll fix that soon. Adding more features later.
Awesome! Without pouring through the code, how did you manage to do this?
#7
Step 1. Acquire Image Step 2. Calculate how many packets will be required to send the image Step 3. Send packet(s) via UDP (1032 byes), populate any outdated data Step 4. Repeat 1 - 3 Receiver Step 1. Acquire a 1032 byte packet Step 2. Translate the packet into usable information (i.e Big Endian to Little Endian) Step 3. Populate "Status" with new information Step 4. If the image is finished, present it Step 5. Repeat 1 - 4 This is, of course, a simplified overview. |
#8
So you segment the image into several packets and send it over UDP instead of TCP? I assume you have error-checking built in? I'll have to check it out.
#9
I carry very little about errors. I throw them out and wait for a new image.
#10
I'm curious - how does this affect the total bandwidth used by a single Crio and dashboard.
In other words, have you increased 20-fold (or is it 20^2 for an image) the number of packets that are going to be sent to increase your framerate by 20 times? For some reason I thought the communication protocalls were sancrosanct - that is I thought we weren't allowed to touch them because of bandwidth concerns. I had thought that was why they limited the dashboard to a 1 hz update, though I might be wrong: you know what they say about assuming. |
#11
Bandwidth Usage:
160x120: 100kbs 360x240: 400kbs (peak, average was around 300kbs) 640x480: Not Tested |
#13
Good work. However, before you train drivers with this video feed available, you might want to ask FIRST Q&A if UDP traffic will be blocked by FMS at competition. Unfortunately, I assume it will be blocked, just like the PCVideoserver port was blocked last year. FIRST is obviously concerned about the bandwidth usage at competition. It would be nice if QoS was used so video could be sent at a lower priority but utilize all available bandwidth.
#14
The source code can be found by using svn.
svn checkout http://frc-video-collab.googlecode.com/svn/trunk/ frc-video-collab-read-only |
| define a new class(C++) | nadavsen2 | C/C++ | 15 | 02-11-2010 13:21 |
| Camera using IterativeRobot class | Steve Warner | C/C++ | 2 | 24-01-2010 21:47 |
| New class for Logitech Dual Action Gamepad | Mike Soukup | C/C++ | 8 | 11-02-2009 20:08 |
| Camera Help (New to Camera Programming) | Idaman323 | Programming | 6 | 14-01-2006 03:56 |
| **FIRST EMAIL**/FIRST Announces New Class of Senior Mentors. | Billfred | FIRST E-Mail Blast Archive | 1 | 23-12-2004 13:32 |
