Go to Post The most important piece of advice I can give is have someone assigned to pay attention to the batteries. You cannot imagine how many teams end up saying "I thought you were charging the batteries..." - RoboMom [more]
Unread 26-01-2010, 08:44
Re: Wireless Bridge Disconnects when driving?
When the bridge is connected to the PD normal outputs and not the dedicated outputs, the battery voltage drops when ever a motor starts or reverses. That is why the dedicated output is required. The PD has an internal boost buck regulator designed specifically for this purpose. The wireless has another problem though. It was not designed to be attached to a moving object and as such has a vibration sensitive power connector and a delicate ethernet connector. Teams should be careful to use wire ties to take the strain and vibration of the these cables so that the vibration doesn't cause noise in the connectors. If you move the power connector and it seems loose, the second contact in the connector is likely out of alignment or you have replaced the power connector with the wrong size part. The power connector should have a firm feel and should provide some resistance to pullout. If it does not, check that the connector is the right size. It that appears correct, the connector on the bridge may be damaged.
Wireless Bridge Problems furiousgeorge Control System 9 28-01-2010 13:28
Help connecting wireless bridge cactuarman Control System 4 24-03-2009 14:24
Wireless bridge not allowing IP change Lord Byron FRC Control System 6 15-01-2009 17:55
Source for Wireless Bridge Gary Bonner FRC Control System 1 07-01-2009 20:57
Wireless Bridge to Nowhere(Help Please!) TeknicllyInsane General Forum 3 11-12-2008 22:40
