Go to Post We should create string networks at Nats. Just have miles of string running between the Georgia Dome and the GWCC. :D - Ctrl Alt Delete [more]
Unread 16-01-2010, 14:59
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
Run dashboard on development computer
Is it possible to run the dashboard on the development computer? If so, how would we go about doing it?
Inspiration of Today,
Technology of Tomorrow.
Team 935
http://www.team935.com
Unread 16-01-2010, 16:59
Re: Run dashboard on development computer
To run the dashboard on a development computer, but the driver station on the Classmate, you navigate to the setup tab on the DS and set the dashboard to be remote and enter in the IP of the development computer. At that point, the DS will forward packets to that IP/port. It is up to you to put the dashboard on the development computer and to start it.
Greg McKaskle
Unread 16-01-2010, 23:26
umangv620 umangv620 is offline
Programming Captain
AKA: Umang
FRC #1403 (Cougar Robotics)
umangv620 will become famous soon enoughumangv620 will become famous soon enough
Go into c:\Program Files\ and copy the FRC Dashboard and FRC DriverStation folders onto a USB and copy them back on another computer.
Unread 17-01-2010, 08:15
Note that copying around executables will work fine as long as the other computer has a LabVIEW runtime engine and other driver files installed on the other computer. If it doesn't work, use the driver station installer, then copy over the EXEs.
Greg McKaskle
Unread 17-01-2010, 10:22
Since the driver station installer installs the dashboard, it shouldn't be necessary to copy any executables.
Unread 26-01-2010, 09:18
ligerbots ligerbots is offline
AKA: Elie GLik
FRC #2877 (Ligerbots)
ligerbots is an unknown quantity at this point
Send a message via AIM to ligerbots
is the driver station install "DSUpdate1.0for2010.zip"? Because I ran that on my Dell development laptop and now do not see the directory FRC Dashboard in program files. Should I just copy the folder from the provided laptop?
Also could I just plug in my laptop with the driver station into the router and use that without setting the ip's.
Thanks!
Unread 26-01-2010, 21:24
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
The Dashboard is contained in a separate update, FRCLabVIEWUpdate2.0for2010.zip.
You could just plug in the driver station laptop without doing anything to change IP's, but you probably wouldn't be able to connect. With the driver station's default settings, the IP will be automatically changed, so it's in your interest to use the 'remote' setting.
Computer Science or Computer Engineering? KRibordy College & University Education 14 09-10-2009 01:56
Robot Run 5K Run/Walk - fundraise or come for the fun Carol Fundraising 0 06-03-2009 16:14
Development on OS X Validius Programming 22 19-04-2008 02:33
Labview Dashboard and updated IFI dashboard spec Joe Ross LabView and Data Acquisition 1 04-04-2006 02:04
Can I run the code on a computer? Anton Programming 1 06-02-2005 05:24
