Go to Post Prepare to be surprised, amazed, awed, and inspired. - Alan Anderson [more]
Unread 26-01-2010, 09:48
Taxi Quinn's Avatar
Taxi Quinn Taxi Quinn is offline
FRC #2389
Taxi Quinn is infamous around these partsTaxi Quinn is infamous around these parts
Program Pnuematics
I have a Team Member who is needing help in Programming. One of his MAJOR problems is he does not know how to program Pnuematics. If you have any links that will help, or advice, please comment. I will have more post soon probably. All help is appreciated. Thank You.
The Big Taxi
Fight, No Flight
"Snarky. Yeah it's a word! Google that...."-Dane Cook
Unread 26-01-2010, 10:11
Re: Program Pnuematics
What language?
There are examples of each we can direct you to.
Unread 26-01-2010, 10:13
Taxi Quinn's Avatar
FRC #2389
English
The Big Taxi
Fight, No Flight
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
It is in the c/java manual on the WPI website!
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 26-01-2010, 10:14
thatoneguy23's Avatar
thatoneguy23 thatoneguy23 is offline
Fiding everything we need to know.
FRC #2389 (Oklahoma STORM)
Team Role: Scout
thatoneguy23 is on a distinguished road
our programmer is using labview, by the way....
I think, therefore I am lost....- Me
"The difference between me and the rest of the world is sanity. They have it, I don't"
Unread 26-01-2010, 10:15
Taxi Quinn's Avatar
FRC #2389
And Where Can i find that. Do you have a link
The Big Taxi
Fight, No Flight
Originally Posted by Taxi Quinn View Post
English
Sorry, solenoids don't speak English.
You can talk at them, but they won't answer except maybe to sigh...
There is a compressor example on the LabVIEW startup screen you can click on to see how it's done.
Unread 26-01-2010, 10:16
Jordan2389Diaz's Avatar
Jordan2389Diaz Jordan2389Diaz is offline
Grant me your power...Verto
FRC #2389 (Pirate Robotics)
Team Role: Tactician
Jordan2389Diaz can only hope to improve
What tools make the pneumatics change is pressure?
Lord is my Shepherd I shall not want-Psalms 23
Taxi Quinn's Avatar
FRC #2389
WE USE LABVIEW
The Big Taxi
Fight, No Flight
Unread 26-01-2010, 10:21
Team Role: Scout
Thanks, Mark. We got it.
Unread 26-01-2010, 10:26
The trouble with the example is that it is setup as a stand-alone program.
It will need to be translated somewhat to fit it into this year's default framework.
For instance, the compressor open and enabled should probably go in Begin.vi
The solenoid stuff belongs in Teleop.vi or Autonomous Independent.vi
Let me know if your programmer needs more and I can knock out a few screenshots.
Unread 26-01-2010, 16:46
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
I'm pretty sure that you can only do so physically through the regulator, I hope someone can prove me wrong though. So in this case you would need to change in between matches, although you could hook up a servo to it, but you would have to gear it to allow multiple rotations.
One other way you could do this is use multiple regulators all being tied to the same piston with solenoids regulating each and fire different solenoids in order to send different pressures to the cylinder.
Another way you could do so would be to only turn the compressor on for a specified amount of time, but the problem with this would be the fact of how unreliable it would be in competition.
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 26-01-2010, 22:50
Sean1038 Sean1038 is offline
FRC #1038
Sean1038 is an unknown quantity at this point
Our team is also using Labview to program.
We had trouble in programming the pneumatics in the beginning too, because we were using the compressor start.vi and Compressor stop.vi for the compressor and the solenoid vis for the solenoid actuator. we weren't able to get those vis to work properly, so we just replaced the Compressor vis and the Solenoid vis with Digital Output vis- that way we were able to set them true or false using a constant.
P.S.- we also used the Digital Input vis for the Pressure switch so the compressor turns off at ~115psi.
Unread 27-01-2010, 07:22
sparks-1784 sparks-1784 is offline
Lance Stronk
FRC #1784 (Litchbots)
sparks-1784 is on a distinguished road
Mark,
We will be programming in labview for the compressor control. If you could include some screen shots for guidance, that would be helpful.
Lance
Unread 27-01-2010, 10:12
Here are those screenshot examples. The autonomous certainly isn't complete. In Auto the robot will turn to face the target, then kick. Of course there won't be a ball there unless you do some more Auto work.
We have a page of screenshot examples from last year that might help some, but they haven't been updated to the 2010 style yet. We'll probably get to that this Sunday.
ID:	8408  Click image for larger version
ID:	8409  Click image for larger version
ID:	8410  Click image for larger version
Pnuematics? Dylan FIRST Lego League 9 07-11-2006 13:49
pnuematics great_one411 Pneumatics 1 16-02-2003 11:50
Pnuematics Manual ark_1230 Pneumatics 2 09-09-2002 18:29
Pnuematics archiver 2001 4 23-06-2002 22:55
Pnuematics Travis Covington Pneumatics 2 22-01-2002 22:09
