Go to Post CD is not the GDC. (Otherwise we'd be better at getting the game hints! ;) ) - Ninja_Bait [more]
Unread 26-01-2010, 11:07
Diana Gee's Avatar
Diana Gee Diana Gee is offline
FRC #1983 (SKUNKWORKS Robotics)
Diana Gee is an unknown quantity at this point
Re: items/devices/mechanisms hanging from robot
Originally Posted by GaryVoshol View Post
Don't let anything hang down so far that you get metal-to-carpet contact.
Im working with a rookie team an I'm wondering if hanging a chain for defense that is not touching the carpet except at the bump is within the rules
Unread 26-01-2010, 11:16
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
I believe that hanging chains/strings/etc constitutes an entanglement hazard as defined in Section 8 <R06> of the game manual.
Unread 26-01-2010, 12:43
Diana,
This is a risky idea on many levels. Objects extending outside the frame for more than two seconds, metal to carpet contact, entanglement, etc. Students need to look over the rules several times before they begin to see them as a sum of parts. Your first stumbling block will be your first practice match when the refs disable you for one of the above rule infractions.
Unread 26-01-2010, 20:53
DonRotolo's Avatar
Back to humble
FRC #0832
Hanging a chain for defense? I simply cannot imagine how this might work. Enlighten me?
Here is what i believe is the relevant rule.
<R08> ROBOT wheels, tracks, and other parts intended to provide traction on the FIELD may be
purchased or fabricated (“traction devices” include all parts of the ROBOT that are designed
to transmit any propulsive and/or braking forces between the ROBOT and the FIELD). In no
case will traction devices that damage the carpet or other playing surfaces be permitted.
Traction devices shall not have surface features such as metal, sandpaper, hard plastic
studs, cleats, or other attachments. Anchors (i.e. devices that are deployed/used to keep
one’s ROBOT in one place and prevent if from being moved by another ROBOT) shall not
use metal in contact with the carpet to “stay put.” Gaining traction by using adhesives or
Velcro-like fastener material is not allowed.
Hanging Mechanisms gorrilla Technical Discussion 17 15-01-2010 23:16
Hanging from the bar: Frank(Aflak) Rules/Strategy 8 22-02-2004 19:49
Robots Hanging from the Floor Todd Derbyshire Rules/Strategy 16 13-01-2004 14:10
Robot Positioning Devices austind27 General Forum 10 11-02-2003 21:58
Robot Mechanisms Image Database archiver 2001 0 23-06-2002 22:14
