Go to Post I don't fully buy into the 'we're all winners' concept. That is a broad statement that doesn't really say much. How did we become all winners? What did we do to become winners? Pay an expensive registration fee and participate in a robotic competition? - JaneYoung [more]
Unread 01-26-2010, 11:18 AM
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Re: MECANUM WHEELS PROGRAMING
I'd assume that GetTwist() gets the z-axis value, which for the KOP joysticks is the throttle at the bottom of it.
Also, this thread is from a year ago, but I created a custom joystick class for use in omni-directional drive trains:
http://www.chiefdelphi.com/forums/sh...ad.php?t=70468
Correct me if I'm wrong, but I believe GetMagnitude() just takes the square root of the squares of the x and y factors of the joystick to get its value (the Pythagorean Theorem approach). This is flawed in that due to special right triangles, sticking the joystick in the corner of its field of motion will generate a magnitude sqrt(2) larger than sticking the joystick all the way to a side. I created my own algorithm which "normalizes" the magnitude of the joystick vector so that it has a max value of 1 all the way around its bounds. Details are in the linked thread.
I wrote the OmniJoystick class before I knew about function overloading and inheritence, so to make life simpler you can change GetAngle() and GetR() in the my code to GetMagnitude() and GetDirectionDegrees() if you'd rather use the "official" function names.
Mecanum Wheels? Maxpower57 Kit & Additional Hardware 17 03-17-2008 04:50 PM
Mecanum Wheels Calvin_1631 Motors 7 02-09-2007 01:29 PM
4 encoders + mecanum wheels programing Smoking_Gun Programming 4 01-18-2007 11:43 PM
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 12-16-2006 07:40 PM
Mecanum Wheels TheFerret Technical Discussion 8 01-16-2006 09:23 AM
