Go to Post The game is leaking? That can only mean... - GeeTwo [more]
Unread 26-01-2010, 11:28
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Re: Spinning the Robot with Mecanum Wheels
Hi Matt,
the pronoun "you" is ambiguous.
which post were you responding to? craigboez or me?
I was responding to craigboez's post.
Sorry about the ambiguity.
Unread 26-01-2010, 11:43
Originally Posted by craigboez View Post
Would anyone be willing to provide a vector analysis of a square 'bot rotating about center?
Hi Craig,
Take a look at this PDF:
http://lib.store.yahoo.net/lib/yhst-...lSpecSheet.pdf
It has a force-vector diagram and complete explanation for all three degrees of freedom: fwd/rev, slide left/right, spin CW/CCW
To spin in place clockwise, wheels 1 and 3 should be driven forward while wheels 2 and 4 are being driven backward. If you do this, the force vectors on each of the 4 wheels will produce torque moments about the center of the wheel pattern all in the clockwise direction. They do not cancel, they add.
Unread 26-01-2010, 11:56
For wheels mounted in the correct configuration, I don't think that it's possible to rotate a bot about center if they are mounted in a square configuration.
Two "RH" and two "LH" wheels, mounted in an "O" configuration, cannot seem to create a moment about the center of a square bot).
The correct configuration is a "X" configuration when viewed from the top of the bot, which is the same as an "O" configuration when viewed from the bottom of the bot. In other words, if you have a bot with the wheels mounted in an "X" configuration when viewed from the top, and you tip the bot on its side and view it from the bottom, it will appear as an "O" configuration.
If your wheel configuration looks like an "O" when viewed from the TOP, it is not the correct configuration, and the bot will not spin properly.
For those of you new to this discussion, here's what we mean by "X" and "O" configurations:
"X" configuration:
"O" configuration:
Unread 26-01-2010, 12:26
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Thanks to all for your input. The fact that the wheels, when viewed from above are different from the wheels when viewed from below was the big aha! moment here. Thanks especially to Ether for the in depth explanation - I have now seen the light.
Unread 26-01-2010, 12:56
Teammax's Avatar
Teammax Teammax is offline
30 Members 6 Weeks 1 Dream
AKA: Rob Cormier
FRC #1071 (Team MAX)
Teammax is just really niceTeammax is just really niceTeammax is just really niceTeammax is just really nice
It is kind of funny because now that I understand the problem I see the answer posted in many places.
Unread 26-01-2010, 13:46
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
The O is the way to go...
"X" configuration:
"O" configuration:
First off, nice ascii art. Good description of the problem as well.
I have been lurking on this thread for a while, but I kept quiet because I didn't really have anything worth adding... ...until now.
When this issue was first introduced in my mind as a potential problem, I had to think about which way I would orient the wheels if nobody told me the answer and I hadn't yet done the experiment. Sadly, I got it wrong. My first thought was to say that I wanted the wheels on the ground in the X position.
My reasoning went like this: I wanted the small wheels oriented such that it would make it easy to spin the robot about its center. An X seems to provide this feature. And it is true as far as it goes -- if you have the wheels in an X configuration and you lock the main axle of the wheels (i.e. turn the motors off), you should be able to spin the robot about its center fairly easily.
BUT... ...then I thought, "What is going to provide that spinning force?"
Well... ...it is SUPPOSED to be the motors driving the main axles of the wheels, of course.
BUT, the way Mecanums work is that they only apply force to the ground in the direction of the axles of those little wheels (the same can be said for holonomic wheels, by the way).
Now that X configuration is a disaster because all the wheel force vectors go right through the center (or very near the center) of the robot!
Torque is force times moment arm: Small moment arms => small torques.
Even if the wheels are putting out largish traction forces, that force is multiplied by as small moment arm. The net result is a robot that has issues spinning about its center.
So... when it comes to Mecanums the O is the way to go.
Cheers,
Joe J.
Team #88, TJ2
Unread 02-02-2010, 18:14
pedro696 pedro696 is offline
None #2564
pedro696 is an unknown quantity at this point
What powerpoint did you use. could you post a link?
2481 Drives Over the Bump with Mecanum Wheels kylelanman Robot Showcase 13 02-02-2010 00:53
Holonomic drive vi with mecanum wheels dwodrich NI LabVIEW 7 18-01-2010 16:01
Help with mecanum wheels CyDrive Programming 7 10-02-2008 16:16
Assistance with Mecanum Wheels CollmandosGrl General Forum 8 14-01-2008 17:42
Teams With Mecanum Wheels Foss@Team176 Technical Discussion 15 06-10-2005 09:38
