Go to Post I don't just participate in FIRST, and it’s not part of my life. FIRST is my life. - sciguy125 [more]
Unread 21-01-2010, 15:27
LANA LANA is offline
LANA is an unknown quantity at this point
HELP FOR THE PARTS ( WHEEL BRACKET)
hi , if anyone can help me to find how to instal the wheel bracket that actually came from the kit!
Unread 21-01-2010, 16:01
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: HELP FOR THE PARTS ( WHEEL BRACKET)
I believe this is what you are looking for.
http://www.andymark.biz/am-0450.html
Edit Here is the link I meant to paste:
http://lib.store.yahoo.net/lib/yhst-...-userguide.pdf
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 21-01-2010, 16:28
thank you so much for ur help! it is what i am looking for
Unread 25-01-2010, 12:56
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
by the way, the KOP Bracket only fits the KOP wheels
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 25-01-2010, 13:15
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
You can probably get the KOP bracket to fit a wide variety of wheels, but you might need to make or buy some extra parts to do so.
Unread 25-01-2010, 13:53
joek's Avatar
too narrow for mechanum and probably omni too
Unread 25-01-2010, 14:07
Chris is me's Avatar
AKA: Pinecone
Omni wheels come as thin as half an inch wide. AM 8 inch plastic omni wheels fit just fine.
Unread 26-01-2010, 05:58
Tony.Wu Tony.Wu is offline
Carnassial
AKA: Dave The Mechanic
Team Role: Animator
Tony.Wu is an unknown quantity at this point
Send a message via MSN to Tony.Wu
You'll need some different sized spacers to fit anything else other than KoP wheels.
Team 3132 is using hardened copper tubing for spacers
Unread 26-01-2010, 10:27
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
We put dual 6" omni wheels in our test chassis without any modification of the brackets.
Unread 26-01-2010, 11:17
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
With a slight modification, the brackets work fine with the AndyMark 8" mecanum wheels. You just need to cut a little wedge out and bend them apart a bit. We're using them right now that way on our practice bot.
For our real bot, we built our own custom brackets. cooler, stronger, and lighter!
Unread 26-01-2010, 13:10
joek's Avatar
us too, I'm the one designing them, (BTW, you NEED a flange on the entire length of the bracket, and don't try steel- too heavy)
Unread 26-01-2010, 14:05
Ours are already built, and as of last night attached to the chassis. Now if only we were done building our custom mecanum wheels... our AndyMark wheels are only for the practice bot
Unread 26-01-2010, 18:00
joek's Avatar
why custom mechanum? regular work fine, and you already have them. we barely have a concept frame, with plywood wheel brackets (although, we are moving along on the sub-systems- i had a design, but the mentors didn't want a 6" wide bracket with welds, and the 4.5 inch design is too weak)
Unread 29-01-2010, 00:55
Brant Bowen Brant Bowen is offline
no team (AndyMark, Inc.)
Brant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant future
Send a message via AIM to Brant Bowen
The 8" Mecanum Wheels should be able to be used with the brackets just by cutting away the aluminum as seen in the picture on the AndyMark website here.
Operations Manager - AndyMark Inc.
Co-Volunteer Coordinator - Boilermaker Regional, Crossroads Regional, Indiana Robotics Invitational
Unread 29-01-2010, 11:59
Cost, for the most part. Part of our intent is to have a practice bot to drive. We got the AndyMark ones first and threw them on the practice bot... but we really didn't want to buy two full sets when we have the resources and capability to make our own and save some money. The drive team has been driving the practice bot for over a week now, and can continue to drive it through ship and the three weeks following before our first competition. Granted, the practice bot only has the drive train... but that's enough for practice.
On a side note, thus far this year we've been moving incredibly fast, compared to the last 3. For the "real" robot, the chassis is finished, the wheel mounts are pretty much finished, the kicker is functional, the lifter is in place (although we're still working on the motor mounts), and the electrical system is probably halfway finished. At this same point last year, we were just finishing our prototypes!
installation for the Wheel Bracket? LANA Kit & Additional Hardware 2 21-01-2010 16:34
Wheel Bracket 2010 in Autodesk Inventor frcchile CAD 2 13-01-2010 14:42
i designed a omni wheel and need help finding money for college vincefitzgerald General Forum 12 19-05-2008 22:03
Bracket for Philly regional anyone? 357_dudeman Regional Competitions 2 27-03-2005 15:28
Thanks for the help and parts, 340! Joe Ross Thanks and/or Congrats 1 22-02-2004 00:09
