Go to Post You can reduce the size of your wench. - ngreen [more]
Unread 26-01-2010, 14:57
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
How do omni wheels work
We are planning on using omni wheels but we aren't sure how they work.
Unread 26-01-2010, 15:02
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Re: How do omni wheels work
Omni wheels work like a powered caster. They rotate when powered like any other wheel and give you flexibility of side movement as well. The rollers are aligned perpendicular to the wheels axis, this allows the wheel to roll on the rollers when a side force is applied.
Originally Posted by AndyMark.biz
These wheels provide propulsion in the forward and reverse direction, while allowing for easy, smooth-rolling sideways motion.
Now, when you use one omni wheel like this: http://andymark.biz/am-0097.html, the rollers do not have a smooth contact to the floor and will shake the robot a little bit. That can be solved for putting two omni wheels together like this http://andymark.biz/am-0432.html.
You can also use omnis to climb over objects like 6" stairs http://www.chiefdelphi.com/media/photos/18050.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 26-01-2010, 15:05
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
What are you looking to do with them? Are you going to try to go in any direction, try to turn better, or some other aspect? Most of the omni wheels that I have seen have allowed the robot to go in any direction. But I have seen quite a few that were used to make the robot turn a lot easier by putting them on the four outside wheels on a 6 wheel drive system. It all depends on what you wish to do with them.
I just posted the image for reference.
Last edited by Cyberphil : 26-01-2010 at 15:06. Reason: Wayyyyy too big of a picture
Unread 26-01-2010, 15:16
AKA: Brandon Liatys
How do you get them to move sideways? We're just trying to move sideways.
Unread 26-01-2010, 15:18
Chris is me's Avatar
AKA: Pinecone
The sideways wheels on an omni wheel are not powered. They just make sideways friction basically zero.
If you want to use omnis to move sideways, you could mount them in a holonomic configuration like this:
Unread 26-01-2010, 15:20
EricH EricH is online now
You need to put one (or one set) per side. You want the wheels to form a box around the robot, something like this: |=| To move forwards and backwards, drive the ones on the sides of the robot. To go sideways, run the ones on the front and back sides.
Unread 26-01-2010, 18:14
riptide's Avatar
riptide riptide is offline
The Software Dude... LabView and VB
AKA: Jeff
FRC #1165 (Paradise)
riptide will become famous soon enough
More than you ever wanted to know about omni wheels.
robocup.mi.fu-berlin.de/buch/omnidrive.pdf
Unread 26-01-2010, 23:35
JohnCushion's Avatar
JohnCushion JohnCushion is offline
AKA: Now
FRC #0190 (Gompei & The HERD)
JohnCushion is an unknown quantity at this point
The "omni" wheels are indeed just like a castor, but they are more stable with side loads then the shopping cart variety. They allow you to turn about the center of your drive wheels. DO NOT try to power them, because they do not operate well in that manner.
If you are looking to go forward, back, sideways and round and round, look into Mechanum wheels.
Here is an example of them in an industrial application: http://www.youtube.com/watch?v=CjcyHicm3NA
AndyMark sells a 6" and an 8" version as well.
There are some issues with them, such as a certain level of finesse needed in the coding of the robot and each wheel needs individual power in order for them to operate properly. They also do not do well when one of the wheels is lifted off the ground. You may also want to look into using a gyro to maintain a certain orientation of the robot as well.
Hope this all helps and good luck with the rest of build season.
Unread 27-01-2010, 01:55
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
I'm not really sure what would cause you to say that. The AndyMark omni wheels have a 1.0 coefficient of friction in the radial (forward/back) direction and I know our team and many others have run them under power just fine.
You won't get as much traction out of them as you will out of a traction tread like a roughtop or wedgetop rubber and you may be easier for other robots to push from the side, but you will still have more pushing force with them powered than you would with them unpowered.
Unread 27-01-2010, 02:05
AKA: Pinecone
I can find you 100 teams that would say otherwise. Powered omni wheels are omnipresent in drivetrains that aren't 6 wheel drop.
Unread 27-01-2010, 02:16
And they aren't exactly unknown in 6WD drop applications, either.
Unread 27-01-2010, 02:46
You need them in this configuration for holonomic use of omni wheels:
http://andymark.biz/am-0478.html
How do you wire the inputs for holonomic drive (omni wheels) star_lancer NI LabVIEW 8 22-01-2010 22:29
caster wheels vs. omni wheels gondorf Kit & Additional Hardware 4 23-01-2008 22:45
How Do Mecanum Wheels Work? SPARKY1688 Kit & Additional Hardware 9 08-01-2007 23:39
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Omni Wheels edomus General Forum 6 06-02-2004 13:35
