cRIO and Laptop Not Communicating ERROR CODE 63
We have hooked up everything, and we did a Ethernet connection from the cRIO to the laptop. When we go to the the FRC driver station and press enable, the words "No Robot Communication" flash red.
Any help at all is appreciated. |
Re: cRIO and Laptop Not Communicating ERROR CODE 63
When you connected the cRio to the Laptop did you use a crossover cable?
Did you load the v19 image onto the cRIO, setting your team's number correctly in the process?
Have you set your team number correctly on the Driver Station? |
We have gotten similar errors(ERR 56 and ERR 63).
Yes, we are using the cross over cable. Yes, we have set up the cRIO and everything else up right. we can run our code wirelessly and tethered and all, but we cant seem to get camera input. We have set up the Camera using the setup axis camera tool and we are able to get a live feed from the web browser, but not on the dashboard. And yes, our user/pass for the camera is "FRC"/"FRC". Hopefully I covered any redundant questions. Overall, We have followed all of the setup guides, and set up everything the way it should. I forgot to check the driver station's diagnostic tab while i was testing the camera, so i did not see what the errors meant, but I will find out next week(midterms this week). |
There is a problem with the driver station update - do you see a camera window to the left of a dial indicator and below two arrows and a cricle and the dashboard?
If not, your driverstation and dashboard did not update correctly. Rerun the update from the developer screen and uninstall it, then run in it once more and reinstall it. |
we have a similar problem. everything is connected, but we cant communicate with the robot. its really weird because in the developer we can go and view our gaming adaptor and our router wirelessly, but we cant use the driver station wirelessly. everything works fine when were teathered though so im pretty sure the problem has something to do with the router...
#7
We can, do, and it works fine
| Driver's Station not communicating with cRio | Alexandstein | Technical Discussion | 8 | 21-01-2010 21:05 |
| cRIO Not Running Code?!? | JohnFogarty | Programming | 11 | 17-01-2010 19:08 |
| Communicating with a laptop | BEEKMAN | C/C++ | 16 | 09-01-2010 21:08 |
| Laptop is not finding the cRIO properly? | Studentish | Electrical | 4 | 07-05-2009 12:03 |
